Well, it depends. The two separate systems are already there so the simplest answer is to plug it in and see if the lights and fans work. If they do and the light is adequate where you need it, you are good to go.
Changing to 120 volt (household) lighting is not simple — you would need to scrap the 12VDC fuse panel and all the fixtures, probably run new wiring to whatever new fixtures you choose... Or, you could just disconnect the 12VDC system and use table/floor lamps plugged into the 120VAC outlets.
Do you want to keep the reefer? It may require 12VDC to operate.
Do you plan to keep the water heater? Furnace? Both need 12 VDC.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
