How old is it? Stored with fuel in the carb, or drained after each use? You may have an air bleed channel partially plugged in the carb. I would disassemble and inspect/clean the carb first.
Also, it is common in even auto engines to have no exhaust valve seal. Since there is positive pressure when the valve is open, there will be no sucking of oil past the stem like in the vacuum of the intake port. Extremely worn exhaust guide will allow some oil to drip through when the engine is off though. Doubt that is your issue with a 23 hour engine.
-Rich-
