Hello,
I have a
1967 Overlander that I have removed the belly skin to start applying por 15 to try an persevere frame as long as possible and noticed a couple spots that need attention.
First is the A frame, the metal bar that runs perpendicular to where the A Frame starts to for a triangle is rusted through. In the right bottom side you can see silver where its rusted through. Can you just cut out and weld in new steel? Its the picture where you can see jack.
Second and what I am more concerned about is a crack in the frame near where outriggers next to steps are welded. You can see its cracked through frame and it looks like someone tried repairing it awhile back with a plate on the bottom. I am wondering if its fixable and if so could be as simple as sistering/welding in plates on both sides for reinforcement?
Third issue have an a couple outriggers that need replaced one has rusted a hole in the frame. Can I just spot weld hole and weld in new outriggers without removing frame?
Nick
