Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity
Old 04-10-2019, 07:39 PM   #1
2018 27' International
Hillsboro , Texas
Amp draw - DC amp meter installation?
Has anyone installed a meter to show amp draw while on DC only?
We had one on our sailboat but the power was all at the Nav Station so easy to accomplish. If you turned on a light or fan you could see exactly what you were drawing out of the batteries. From that you had predictability.
I can read the draw on the labels and manuals but that only tells part of the story.
Btw: I have an induction clamp for my VOM but the margin of error is too great to be of much help.
Thanks - Jim
GypsyCan is offline   Reply With Quote
Old 04-10-2019, 07:56 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Lots of people do it.
Victron makes a very easy to use and nice one.
Here is my blog post on my install.
http://www.airforums.com/forums/blog...-install-2987/
https://www.victronenergy.com/batter.../bmv-712-smart
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
GMFL is offline   Reply With Quote
Old 04-10-2019, 08:02 PM   #3
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Yes, shunt style battery monitors are really the way to go if you want to really know what's going on with your battery. I use the Magnum BMS that talks to my inverter charger. As @GMFL mentioned, Victron makes a nice one. There's also a standalone model from Bogart Engineering called the Trimetric that's very popular.
TheGreatleys is offline   Reply With Quote
Amp draw of appliances KYAirstream Electrical - Systems, Generators, Batteries & Solar 21 07-22-2020 06:11 PM
On The Go Portable Dual Bed Deionizer Tanks & TDS Meter Road Dog Airstream Classifieds 0 05-16-2017 12:33 PM
low voltage cutoff vs AMP hours used at high amp draw morgandc Batteries, Univolts, Converters & Inverters 0 11-02-2014 09:38 PM
Vent lift installation & Astrodome installation jessejane Roof Vents, Skylights & Fans 4 01-10-2014 04:34 PM
Amp Draw for Dometic Refer tinbender Refrigerators 1 06-12-2007 09:36 AM
