12-10-2015, 07:51 PM
#241
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Looking great Peter, I hope to witness in person sometime.
12-10-2015, 08:05 PM
#242
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Sorry for sideways pictures, can't control them from cell
AIR #13
12-13-2015, 03:08 PM
#243
Airstream Driver
1994 30' Excella
Austin
Our Blanco Christmas Rally turned into a mini Motorhome Rally with Chris's 350LE, Bills 325 and Bens Argosy.
Always lots to talk about when the MH heads get together
AIR #13
12-13-2015, 07:23 PM
#244
Airstream Driver
1994 30' Excella
Austin
AIR #13
12-13-2015, 08:06 PM
#245
Foothill Ranch
Looks like fun!
12-14-2015, 02:28 PM
#246
1987 32.5' Airstream 325
dripping springs
Peter:
Thanks for the invite! We really had fun and it was great to have people to associate with screen names. A great bunch of folks for sure! Next year we'll be in for the duration. It was a pleasure to meet everyone and particularly to talk motorhomes and see others! Thanks again!
-Bill
-Bill
12-16-2015, 03:13 PM
#247
1982 31' Airstream 310
champaign
There ya go Peter. I guess I should have posted that in the 12v thread. But it looks like the exact same as yours. Pay no attention to the red #12 with the yellow connector coming off the top on the right post. I picked up power there for something else. But it does look like a #10 like yours in question.
12-16-2015, 04:04 PM
#248
Airstream Driver
1994 30' Excella
Austin
Originally Posted by mayco
Attachment 253974
Thanks Mike.
I just don't get why they used a 10 ga wire to run 5 feet back to the starter relay and on to the battery on 1 lead and to the fuse box on another.
Any wiring experts that can shed some light on this ?
AIR #13
12-16-2015, 05:07 PM
#249
Richmond
, Kentucky
Peter, here's the radiator shroud from the 345.
As you can see it is a 2-piece affair.
1975 24' Argosy Motor Home
12-16-2015, 05:13 PM
#250
Richmond
, Kentucky
Originally Posted by PeterH-Airstreamer
Thanks Mike.
One of the wires in the diagram I posted is a 16 gauge fusible link. I think the thing that surprises me the most is the battery charging circuit passes through this fusible link. Not sure how that's supposed to work especially with an alternator putting out 140 amps or more.
Hopefully someone smarter that us will chime in and explain this configuration!
Sorry, I'm no help on this one
12-16-2015, 05:14 PM
#251
Airstream Driver
1994 30' Excella
Austin
Attachment 253988
Awesome, Brad. I will be installing a new fan clutch this weekend and can investigate my situation a little closer.
AIR #13
12-16-2015, 05:16 PM
#252
Richmond
, Kentucky
Don't be afraid to grind or or otherwise remove the rivets from that metal guard to give better access. Just get four 3/8-16x1" grade 8 bolts and bolt back in place when you're done.
Your knuckles will thank you!
12-17-2015, 10:30 AM
#253
Airstream Driver
1994 30' Excella
Austin
Fan clutch was easy to reach from above.
And Lo and Behold, my fan shroud is a 2 piece as well. Thanks for the offer, Brad.
AIR #13
12-17-2015, 11:42 AM
#254
Richmond
, Kentucky
I assume you mean that you want the fan shroud shipped your way?
12-17-2015, 11:46 AM
#255
Airstream Driver
1994 30' Excella
Austin
No Brad, save it for someone that really needs it. Since I have the 2 part, I am fine with my patch.
AIR #13
12-17-2015, 12:09 PM
#256
Richmond
, Kentucky
So far it would appear that the demand for fan shrouds isn't all that great
I'll just leave it in the barn for the time being...
12-17-2015, 08:29 PM
#257
Airstream Driver
1994 30' Excella
Austin
Darn fan clutch took longer than I thought, but I was able to get it out and in from above. Took her for a long hard drive, new fan clutch never engaged, since I stay under 200. Just had a problem at the parade last weekend. They were moving at walking speed and half way through the parade it was running at 220, with no clutch engaging. I turned all the heaters on full blast for the rest of the parade.
Unfortunately, I still have the voltage fluctuation. I guess its time for a new alt
AIR #13
12-18-2015, 05:57 AM
#258
Richmond
, Kentucky
I'd say you got that problem whipped! Where did you buy your fan clutch from?
Have you have the alternator tested under load by a repair shop? Not sure they could detect the problem you having but you never know.
12-18-2015, 06:06 AM
#259
Airstream Driver
1994 30' Excella
Austin
Rockauto.com ACDELCO 154949 (thanks Chris for the part number)
That's my plan for today, but it has to come out from below or the side Stop by, if you are in the neighborhood
AIR #13
12-18-2015, 07:57 AM
#260
Richmond
, Kentucky
Thanks, Chris & Peter.
If the fan was removed could you bring it out the top?
Wish I had the time to drop by but unfortunately I've got an Argosy to rebuild and a friends house to help finish
