Old 07-17-2020, 10:44 AM   #1
1986 34.5' Airstream 345
Glencoe , Oklahoma
Koehler Generator Not Starting
I am having some issues with my generator not starting. I have 12 volts to the solenoid. I checked the pigtail where it plugs into the start switch and I have 12 volts on one wire. I can jump the solenoid and the engine turns over but will not start. It’s like I don’t have power from the start switch to the solenoid? Any idea where this is fed from? Should I have power to either of the small wires on the solenoid? I cleaned all the terminals on the solenoid as well. This is a Koehler 7000w in a 86 345.
When this issue started I had just left camp and the generator died and wouldn’t turn over after that.
JJ1965 is offline   Reply With Quote
Old 07-17-2020, 10:52 AM   #2
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
enough fuel? pick up tube for genny only goes down ~ 3/4
AIR #13
PeterH-350LE is offline   Reply With Quote
Old 07-18-2020, 05:16 AM   #3
I had similar starting issues with the Koehler generator in my 310. The issue ended up being the shutdown solenoid that stops the gas feed through the gas line. The solenoid is powered by the same wire that feeds the ignition coil. It's been a number of years so I don't remember all of the details but what happens is the shutdown solenoid starts to fail and as it fails it draws more current which in turn reduces the voltage at the ignition coil.
Here is a link to my post when I first started troubleshooting the shutdown solenoid problem.
1975 24' Argosy Motor Home
Old 07-19-2020, 05:01 PM   #4
Glencoe , Oklahoma
Thank you
That is helpful thanks for sharing I’ll look into my next day off!
Accidentally re-starting a generator while hooked up to the trailer Rpatrick16 Generators & Solar Power 35 03-28-2018 06:28 PM
Honda Generator Starting Problems rocco52 General Repair Forum 13 01-01-2018 11:20 AM
Generator not starting Edistobob Sprinter and B-van Forum 4 05-14-2017 05:22 AM
Suggestions on Starting Generator after sitting 92landyacht Land Yacht/Legacy Motorhomes 30 12-04-2011 04:25 PM
Generator not starting the AC trearick Generators & Solar Power 2 08-21-2011 07:05 PM
