Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 03-09-2018, 04:50 PM   #381
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Any pictures ???
bobmiller1 is offline   Reply With Quote
Old 04-07-2018, 03:37 PM   #382
1995 36' Classic 36
Ludington , Michigan
Originally Posted by Kota View Post
I’ll try to get some pictures later today.
The black and grey drain pipes are insulated between the tank enclosures and the access locker.
Kota is offline   Reply With Quote
Old 04-07-2018, 03:52 PM   #383
bobmiller1's Avatar
Pretty neat....looks like it may have been well thought out, is that AIRSTREAM's doing or yours ? Regards, Bob
Old 04-07-2018, 04:10 PM   #384
1995 36' Classic 36
I was like that when I bought it. Looks factory.
Old 04-08-2018, 02:01 AM   #385
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
That shows the box duct along the length of the coach and the duct to the insulated tank. How does the water locker (dump valves, water drain, and hookups) get it's heat?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 04-08-2018, 04:13 AM   #386
1995 36' Classic 36
One of those tubes from the duct goes to the water locker.
Old 04-08-2018, 10:23 PM   #387
Vycan's Avatar
Thanks!
Old 04-15-2018, 10:12 AM   #388
Vycan's Avatar
Kota,
I really hope work approves going to the get together because mine looks a bit different, and I will just want to crawl under yours and look around. On mine, i have the same metal lateral running conduit, but only one hose coming out, and it goes to the tank. The water closet receives no heat, and the plumbing from the tank is not insulated. I am wondering if it is a function of yours being a 95, or if they just cut a corner on mine.
Old 04-15-2018, 01:04 PM   #389
1995 36' Classic 36
Really looking forward to seeing you guys again!
Old 06-12-2019, 08:02 AM   #390
Vycan's Avatar
Hello Team,
Been away for a while. Moved to Colorado Springs. Family is well. Just finished a 3-week 6,000 mile road trip across the US, and our only mechanical issue was a pin hole in an old boost boot causing a slight leak. Will not make the get-together this weekend.
Oddly we did lose an AC shroud in our last day of travel, and have a replacement on the way. (No idea where we lost it)
Old 06-12-2019, 10:22 AM   #391
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Howdy Vycan, was just thinking about you and the family yesterday. Was wondering how y'all are getting along. Kids must be growing like weeds. Good to hear from you
mayco is offline   Reply With Quote
Old 06-12-2019, 02:22 PM   #392
bfred's Avatar
2003 39' Land Yacht XL 330 hp w/2slides
White Lake , Michigan
Fuel Filters for CAT 3126E
Just a heads up. Like your heater motor, mine had a few DC electrical issues. They have all been due to poorly implemented grounds. Many of the grounds on mine were a screw through the carpeting. As the carpet compacts over time the connections become loose. This was the case on my HWH leveling system, vacuum pump, dash heater motor, and coach power solenoid. Correcting the grounds solved all the problems the PO had been fighting. Possibly why he unloaded it.
Just starting to clean garage out after moving and discovered two brand new fuel filters which I have no use for as we sold our 396XL 2 years ago. If anyone on this thread has use for them,pay the shipping and they are yours.
Alliance p/n ABP/N122-32FRT03
2003 Land Yacht 396XL
Blue Ox Alladin
2008 Jeep Liberty
bfred is offline   Reply With Quote
Old 02-01-2020, 11:52 AM   #393
Vycan's Avatar
Hello Team,
Been a while again. Just finished a cross country road trip to disneyworld and back to the springs just shy of 5,000mi. No issues except a pocket door coming off it's suspended roller. The fun part was a screw that held up the track was the culprit, and it was a solid 18 inches into the pocket. Fortunately Pam has small hands and could get her hand around a thin handled screw driver. She could not apply upward force while turning, but I could slide my hand in like a knife and lift. it was pretty hilarious in retrospect. Kids are 9 and 6. Our youngest is so spoiled because he has had DD his whole life. Our oldest thinks no one should vacation without a DD.
I have to say I hate spending money on frivilous stuff, but the campground at Disney gives you quite a few perks.
1. $100 per night full hook ups, great spots, relatively private
2. Free magic bands to use with your tickets
3. Can eat at the motorhome to mitigate costs, or travel outside with your toad. (we did not do this though and budgeted for dinners at epcot)
4. Free parking at the central parking areas, or take the ferry direct from the campground to the park.
On average an RVer can experience Disney for about 50% of the total cost for a week-long trip.
Fuel economy was 11.5 mpg going there, with 10 mpg when crossing the Appalachians, while going 67 mph. On the way back we did 73mph and got 10mpg, with 9mpg coming up through alabama, and back through Kansas, dropped speed to 63MPH and jumped back up to 11.5mpg. All while towing the saturn.
Hard starting only at altitude. No hard starts, at any temp below 3,500ft MSL. (Stopped in KS and TN on the way. Sub freezing and freezing temps at start respectively.)
Not camping as much as I'd like, and unable to make the eastern get togethers, but I am half way through current time at this location, so maybe again in a few years.
Other news, now have three dogs.
Will check in more often once the job calms down. Finish this position this summer. A whole six months longer than scheduled.
Old 02-01-2020, 03:45 PM   #394
1995 36' Classic 36
Good to hear from you! Didn’t get any interest in a spring gathering in Michigan so we’ll see if anything else develops. We will be doing a road trip to Boulder this spring. Maybe we can get together. Still medically DQ from work but doing well.
Old 02-01-2020, 07:29 PM   #395
Vycan's Avatar
Would love to have a camping get together. Could do another one at the Chyenne Mountain state park
360 Classic Diesel - Need Thoughts! Bambi_Bandit Classic Motorhomes 14 03-15-2018 07:09 AM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
Advice on a 95 360 diesel pusher Rosie39j Classic Motorhomes 4 05-16-2011 03:45 PM
