RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-05-2018, 06:14 PM   #1
2016 30' International
Hampstead , North Carolina
Propane Leak
Greetings. I have searched a number of existing threads on this topic and would like a little clarification please. Hopefully my picture posted correctly.
I have detected a very small propane leak. No real sound or smell, but my soapy water test shows bubbles from the screw on connector end of the hose. It seems to be pretty straightforward to replace the pigtail. Can anyone look at this pic and tell me whether this hose is the inverse flair type or the standard thread type?
If this is an inverse flair, do I use any yellow Teflon tape or pipe dope?
Again, if you can see the pic, there is some kind of red sealer on the end of the hose that connects to the controller. What is this and where can I get it?
Thanks for your assistance.
Edward
Name:	Propane Pigtail.jpg
thegypsy is offline   Reply With Quote
Old 12-05-2018, 06:37 PM   #2
1981 31' Excella II
New Market , Alabama
Just search Amazon if you don't like these.
https://www.amazon.com/SHINESTAR-Pig...+pigtail&psc=1
Old 12-05-2018, 06:46 PM   #3
Propane Leak
Thank you. My existing pigtails seem to be 10 inches long. I read in another thread that it was difficult for a 12 inch pigtail to fit in the cabinet without a very sharp bend in the hose. Is this correct?
Old 12-05-2018, 07:06 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
I just replaced mine a few days ago for the exact same leak. Mine were MPT, not inverted flair. My regulator is a Marshall, without the inverted flare adapters.
The only way to know for sure is if you remove the hose, it should be easy to tell which is needed.
I think MPT thread goes into the regulator. If inverted flare was needed, there would be a brass adapter screwed into the regulator, then the pigtail into the adapter.
I would not use yellow tape. I prefer paste. Either way the package should say "for Natural Gas". I like Rectorseal #5
I used these>
https://www.amazon.com/Rectorseal-25...09119845&psc=1
https://www.etrailer.com/Propane/MB-...73-15-MBS.html
MB Sturgis products are "Made in USA"
Alan
Old 12-05-2018, 08:33 PM   #5
Propane Leak
Thanks, Alan. Did you purchase the 15" hoses? Were your existing hoses 10"? How was the fit in the propane enclosure?
Old 12-05-2018, 08:35 PM   #6
2002 19' Bambi
Lafayette , California
I just replaced our propane pigtails with the 12" Sturgis version of A W Warn's link. I also purchased them from eTrailer.
We had 12" hoses before, so replaced them with the same length. Only one was leaking, but it seemed prudent to replace both.
Tim
Tim A. is offline   Reply With Quote
Old 12-05-2018, 09:42 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I did purchase the 15" hoses. The original hoses on my Excella were 18" according to the manual, but those I replaced were 15".
My Safari has 15" also. I replaced them about 3 years ago.
Both of the tank covers on my trailers have sufficient space for these hoses.
ps: the hose measurement is the entire hose assembly. (including the threaded end, hose, and the acme nut)
Alan
Old 12-06-2018, 04:46 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Also use a Marshall valve/regulator...used these, stainless critter protection. 🥴
If in doubt...
“I’ve always thought that over planning was just a firewall against not being sure of what you really want to do.”
RLC
Tahawus
Old 12-07-2018, 03:04 PM   #9
2016 25' Flying Cloud
2010 20' Flying Cloud
Los Gatos , California
Yes it's a Male pipe thread. You want to use the yellow teflon tape (for gas fittings)
TerryC
TerryC is offline   Reply With Quote
Old 12-07-2018, 05:20 PM   #10
2007 22' International CCD
When you use yellow Teflon tape with propane fittings, wrap the tape on the male part of the fitting such that NO Teflon tape goes past the end of the threads on the open end of the fitting. This is to prevent little threads of Teflon coming off and migrating into the propane system. I can guarantee you that said debris WILL end up right where it will cause the most trouble.
Murphy's law applies to Airstream systems as well as anything else in the world...what can go wrong, will go wrong, at the most inconvenient time...
Old 12-07-2018, 05:44 PM   #11
2020 23' Globetrotter
Savoy , Texas
post 1 has a picture of the same gas line as ours. In that picture shows a black line by the green knob. That is a rubber material washer. Our black washer cracked in several places and fell apart. This is where propane was leaking. The other hose was doing the same thing.
SpinWhite is offline   Reply With Quote
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 09:56 AM
Newbie Advice on Propane and Propane Accessories Socal1 LP Gas, Piping, Tanks & Regulators 1 07-15-2013 01:36 PM
Propane valve leak Dbraw LP Gas, Piping, Tanks & Regulators 3 06-14-2002 07:12 PM
