Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 09-15-2021, 12:45 PM   #1
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Rear window screens
Since I travel with a cat, it has come to my attention that I need to replace my rear side window screens with a pet proof screen. How do the screens come off? It seems they may be glued down with a black foam tapeClick image for larger version
Mansderm161 is offline   Reply With Quote
Old 09-15-2021, 12:48 PM   #2
There are heavy duty pet screens available, I just need to be able to access the outer side where the cording is. The pet screens don't tear as easily from claws. Click image for larger version
Old 09-15-2021, 06:48 PM   #3
2013 Interstate Coach
Waterloo , Iowa
On my 2013 all the screens snap in - clips several places around the perimeter. Your 2018 may differ.
Titus is offline   Reply With Quote
Old 09-15-2021, 08:41 PM   #4
2018 Interstate Lounge Ext
LV , Nevada
On my 2018 - First make sure the control knob is turned so it does not obstruct the upper corner of screen frame. Then grab both sides and pull out, see pics below.
ID:	404131   Click image for larger version
Alex AVI is offline   Reply With Quote
Old 09-16-2021, 06:20 AM   #5
2017 Interstate Lounge Ext
Mount Jackson , VA
Since I travel with a cat, it has come to my attention that I need to replace my rear side window screens with a pet proof screen. How do the screens come off? It seems they may be glued down with a black foam tapeAttachment 404101
Cat lover here. "If I fit, I sit" is all that came to mind with your cute kitty picture. Now, please no one yell that I am not staying on topic. The question at hand has been answered.
MountainLife is offline   Reply With Quote
Old 09-16-2021, 11:50 AM   #6
Thanks so much for the answer. Screen project when I get home. I already bought a roll of the pet proof screen, the cord, and the tool...he tried to get thru my home patio screen door to catch a lizard...he didn't get far but tore a nice hole! He's worth it...he's a good traveller.
Old 09-16-2021, 12:34 PM   #7
LV , Nevada
Closeup of the 4 internal clips. If they've never been removed, it will feel very stiff and feel like you would destroy the screen frame if you continued to pull. But it will pull out regardless without destroying frame or clips (as may happen with plastic trim clips often). These are metal clips.
ID:	404172   Click image for larger version
Old 09-17-2021, 06:45 AM   #8
Got the screens out, but for anyone interested, I don't think the pet proof screen will work. It is thicker than regular screen and the holes are bigger. My first concern is gnats might be able to get thru. Second, it's plastic, not very pliable so getting it in the groove is a challenge. There are 2 rows of grooves, original screen is splined in the smaller inner groove. The outer groove is actually larger, but the clips are in that groove. The screen is too thick to fit in the inner groove. If I do the outer groove, no way to spline at clip points. Also .140 spline is too big for either groove if using this screen. The original spline is smaller and in pretty good shape, but it's too short moving to the outer groove. So, plan B on the way from Amazon: regular screen and smaller spline. I'll have so much extra screen, I guess I can just redo it any time my dear kitty claws it or pops it out. As he gets older, he may be less interested!
Front, side and rear door screens—Who needs them? duckdave Sprinter and B-van Forum 11 07-01-2019 12:14 AM
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 11:48 AM
Replace window screens Marc Windows & Screens 6 08-12-2004 03:35 PM
window screens - fuzzy things Craig Windows & Screens 2 09-03-2003 07:18 AM
old style 50s window screens ???WHERE? oldvws Our Community 1 12-14-2002 01:10 PM
