Old 11-22-2019, 04:51 PM   #1
2016 Interstate Lounge Ext
Lake Oswego , Oregon
black gfi outlet dead
my 2016 interstate lounge black gfi outlet is dead, will not reset.
Its in the 20amp breaker.... inverter..........black gfi (located behind drivers seat)..... front TV and Blueray player circuit. ( tv and blueray not functioning as a result of the gfi not resetting)
Inverter seems to be functioning properly green lite flashes once per second.
Have not reset inverter yet.
Have reset the 20amp breaker at the start of this circuit.
Has anyone had any success in making this repair. Any input is appreciated.
Joe
joe rv guy is offline   Reply With Quote
Old 11-22-2019, 08:22 PM   #2
2016 26' Flying Cloud
Southlake , Texas
Don't have an Interstate but did have problem with gfci circuit. A new breaker from Home Depot cured the problem.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 11-23-2019, 04:02 AM   #3
Auburn , Georgia
Joe, Look on top of the Magnum inverter, there will be a small 5 amp ? circuit breaker.
A reset should fix the problem. The outlet won't power much without tripping.
GETRIDAONE is offline   Reply With Quote
Old 11-23-2019, 12:57 PM   #4
fixed it
fixed, 5amp breaker on inverter was tripped. Problem solved, thank you
Old 11-23-2019, 03:03 PM   #5
Auburn , Georgia
Glad you got it fixed
Old 06-04-2020, 09:37 AM   #6
2021 Interstate 19
Menlo Park , California
I have 2020 Interstate 19 and appear to have same problem. GFI Test doesn't work and all the GFI outlets dead. Inverter appears to be working powering other outlets (TV) on the non-GFI side/circuit. Tried toggling 20A GFI circuit breaker but to no effect.
csb333 is offline   Reply With Quote
Old 06-04-2020, 09:55 AM   #7
2021 Interstate 19
GFI Circuit Out 2020 Interstate 19
Inverter is green and appears to be working; test on the GFI circuit breaker is dead and no power on the circuit--3 outlets including microwave
Any idea?
Old 06-04-2020, 10:12 AM   #8
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
The Airstream Owner's Manual should be a lot more empathetic that nothing that draws more current than electronic items should ever be plugged into the two TV outlets and the outlet in the over-cab compartment. Also, during the purchase walkthrough, techs should explain why. I doubt whether very many do.
I do have a mini-PC mounted on the wall over the desk in my GT and connected to the TV below as a monitor. Nothing else gets plugged into those three outlets.
I ran #12 wire and installed an outlet on the front side of the galley counter so that I can safely run a ceramic heater in the front of the coach in cold weather. If I want to use the AC charger for my Yeti under the desk, I run the cord across to my new outlet and cover it with a rug for safety. The photo was before I installed the plate on the outlet.
Name:	Outlet installed.jpg
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Dead Elcetrical Outlet - In Cabinet above Main TV rspecialk Electrical - Systems, Generators, Batteries & Solar 9 11-08-2019 11:38 AM
GFI outlet location tcrum 1974 - 1979 Sovereign 11 02-21-2018 06:22 PM
Dead battery bad GFI perryg114 Batteries, Univolts, Converters & Inverters 13 10-25-2017 10:44 AM
First time out - dead outlet on 2nd day losfeliz Lights - Interior & Exterior 10 10-11-2016 06:43 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
