MCRIDER - Do you know if that 2018 AI has VB Air suspension and E&P Hydraulic levelers?
Alex, sorry for no response. Have been out in Big Bend with little to no connection RVing, Bicycling and motorcycling. I see Mike got further details. I'll be visiting Smokey Mountain Motorcoach week after next so should have further details afterwards. I'm likely to go the Volta route.
Visited with Gary and Smokey Mountain Coach Works today. He has three Volta installs before he could even get to mine and so winter '19/20 earliest. He confirmed that the Power Module is a direct replacement dimensionally for the generator. Was able to see a Pleasure Way install he has done. He also suggested that we can install the inverter in an enclosure where the OEM House Batteries are located so no loss of space inside. Considering the same for the 48V/12V converter and the Volta Power regulator. In the Pleasure Way, these are mounted under the passenger seat.
Next step is to provide him a power configuration we want and then the dreaded quote!!!
