Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1984 - 1989 Sovereign
Old 11-22-2002, 12:54 PM   #1
tomb's Avatar
Images: 8
water heater bypass
anyone had a ploblem with there factory installed bypass? small square box inside side door at water heater, mine was leaking and when I went to winterise it sent antifreeze to the water heater with it in the bypass mode....can it be bought or is there a good fix ???? thanks Tom
TOM BOONE 1987 SOVEREIGN 25' WBCCI#14120
tomb is offline   Reply With Quote
Old 11-22-2002, 01:04 PM   #2
Gordon Watt's Avatar
The bypass one my heater was leaking and I found the bottom end of the pipe was too tight and squashed the washer which is quite thick and got distorted.
Your friendly RV person should have some for you. My dealer didn't charge me for it.
Be careful installing it as they are thick and should not be tightened too much or they will leak and/or restrict water flow.
Gordon Watt is offline   Reply With Quote
