Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures
Old 06-03-2018, 12:00 PM   #1
TCwheels's Avatar
2019 25' International
Traverse City , Michigan
Replacing cracked FW tank - advice?
The fresh water tank in my 2011 FC 20 is cracked and leaking. The dealer tried an outside glue and patch that did not work, so I've purchased a new tank and am going to remove the old tank and replace it with the new one.
My two biggest unknowns at this point are: How to disconnect the pour-in tube inlet from the top of the tank when I'm removing the tank from underneath the Airstream, and how to remove and reinstall the water level sensor on the tank.
Any advice relative to this job would be greatly appreciated!
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 06-03-2018, 12:15 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Here is my recent swap.
http://www.airforums.com/forums/f443...3d-181076.html
Filler hose as well as the vent hose will need to be disconnected from the water fill on the side of the trailer and worked down through the floor as you drop tank.
If you have a SeeLevel tank monitor system you will need to purchase a new sensor for your tank and put the new sensor on the new tank.
Old 06-03-2018, 12:16 PM   #3
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here’s a few pics.
ID:	312843   Click image for larger version
Old 06-03-2018, 12:18 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I also had a low point drain to contend with. Not sure if you do on you 20 footer
Old 06-03-2018, 12:19 PM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
More pics.
ID:	312851   Click image for larger version
ID:	312853   Click image for larger version
Old 06-03-2018, 04:30 PM   #6
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Ronnie,
My 2014 FC23d FW tank drain valve is leaking ever so slightly. Always some water on the little bent metal piece meant to protect it. I want to fix/replace but don't want to break anything and create a big disaster that requires me to drop the pan.
When I remove the two screws at the valve flange on the outside, is the valve assembley then threaded into the tank, so I can replace with a new drain (maybe something upgraded) with some teflon tape...or is there some other more complicated attachment to the tank? I'd rather just leave it for now rather than create a big project if it's not a simple threaded fitting I can easily remove. And I sure don't want to break anything and be SOL and facing a major fix.
Thanks. Sorry for hijacking the thread but it's related sort of :-)
PK
pcskier is offline   Reply With Quote
Old 06-07-2018, 01:46 PM   #7
TCwheels's Avatar
Thank you so much! Your advice and thread were incredibly helpful. It WAS a fun task with one challenge after another. Stayed calm and problem-solved.
Old 06-09-2018, 09:46 AM   #8
TCwheels's Avatar
Some pics from the job...
Tray and tank removed
Tray with factory “insulation”
Old tank
Broken plastic boss (source of leak) that dealer tried to fix with goop
Replacing cracked windshield amirm Sprinter and B-van Forum 16 07-12-2017 07:58 PM
cracked grey water tank Surprise Classic Motorhomes 35 11-21-2013 08:51 AM
Cracked Black Water Tank Invert Repair toga Waste Systems, Tanks & Totes 5 03-25-2009 08:35 AM
Black Tank Cracked....HELP rlindberg Waste Systems, Tanks & Totes 10 03-21-2009 06:19 PM
water heater tank cracked. JB weld? Curtis-79MH Classic Motorhomes 12 06-09-2007 04:07 PM
