Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 08-10-2020, 08:15 AM   #1
2019 Interstate Grand Tour Ext
Dover , Massachusetts
Comfort of the bed
I have a new Interstate 24 GT on the way. My question is about the sofa that converts into a bed. There are a lot of bumps and lumps on the bead caused by the contouring of the sofa. Is it necessary to place a foam covering or something else over the bed for comfort? Or is is comfortable enough even with the bumps.
Status Bill is offline   Reply With Quote
Old 05-05-2021, 08:58 PM   #2
2015 25' Flying Cloud
Washougal , Washington
The bed/lounge is not at all comfortable. We tried a 2” foam pad and that was not enough so we are now using a 3 inch foam pad which works best. It is very bulky so we roll it and it is covered with a pillowcase style bedsheet. There is no need then for making the bed with bedsheets. Just pull out pillows and comforters.
While it is inconvenient to unroll this foam pad every night and again roll it in the morning, it is worth the trouble for comfortable sleeping.
We made a rack where the rolled pad sits out of our way while traveling or when we use the area as a lounge.
Good luck with your GT.Click image for larger version
ID:	394974Click image for larger version
Blissful is offline   Reply With Quote
Old 05-06-2021, 08:27 AM   #3
Airstream bed comfort
I don't know what people are thinking when they say the bed is not comfortable. We just finished a 2 week trip in our new Interstate 24. The bed was fine -- you do not feel any of those bumps. My wife is the most sensitive person in the world when it comes to bed comfort, and she was happy. Don't waste valueable space with foam tops. The bed is great, the 24 is great.
Old 05-13-2021, 09:13 AM   #4
2017 Interstate Lounge Ext
Abilene , Texas
For our interstate, I purchased 2 poolside lounge chair mats and we use sleeping bags on the twin bed configuration that allows for easier access. That worked a lot better than trying to fit sheets etc on the queen configuration.
Julie Hagin is offline   Reply With Quote
Old 05-13-2021, 09:17 AM   #5
Abilene , Texas
2021 Atlas Murphy Bed
How thick is that mattress? I am trying to order custom sheets.
Old 05-14-2021, 05:06 AM   #6
It is hard to tuck in the bottom sheet. Not enough room. Put a comforter down for the bottom, then a standard queen size for the top.
Old 05-14-2021, 08:41 AM   #7
It is too awkward to put sheets on the “lounge bed” or even any foam topping. Our foam pad is slipped into a pillowcase style sheet and stays in for the duration if the trip. No slippage. Very easy to roll and unroll and stays clean.
Old 05-19-2021, 02:26 PM   #8
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The "bed question" was pretty much at the top of our list when we went over to look at the GT. We spend a few hours poking around, with 3 of us trying this and that. Based on a brief "survey" of the bed, it's not that bad if you sleep on your side and are between the seat side "bumps". That was the consensus from all three of the "inspectors"
Old 09-27-2021, 08:25 PM   #9
JCS
Southlake , Texas
We started with a full size sheets and blankets, but moved to the Disc-O-Bed Duvaley Luxury Sleeping Pad Duvet (Amazon) and really like them. Basically a memory foam base tucked inside a duvet. Very comfortable. They also store easy and the cover/duvet can come off and be washed in a washing machine.
JCS is offline   Reply With Quote
Old 09-27-2021, 08:47 PM   #10
ScottP's Avatar
2020 27' Globetrotter
2019 Interstate Lounge Ext
Jackson Hole - Tetons , Wyoming
Good luck with your GT.Attachment 394974Attachment 394975
Shelf for rolled pad:
Thanks for sharing this, it’s something I didn’t know I needed until I saw your image. I tend to stack and pile stuff behind the bench seat … and when i open the rear cargo doors … it all comes tumbling down!
Usually we have an ARB fridge-freezer plugged in back there behind the bench seat also. So your shelf will work out great!
Thanks!
ScottP is offline   Reply With Quote
Old 09-28-2021, 07:01 AM   #11
We have the same rig, have had it for a year. The bumps are no problem. What we do is put a comforter down in place of a bottom sheet since it’s very hard to tuck in a sheet. Then whatever for the rest of the bedding. Never feel the bumps. Don’t waste valuable space with foam.
bed comfort/memory foam pennylane69 Modifications 5 10-10-2020 11:49 AM
2017 Classic 30 Queen Bed Comfort paultreible 2016 - Current Classic (all lengths) 1 03-06-2017 11:34 AM
Bed Comfort Question jerem0621 All Argosy Trailers 13 01-03-2010 10:09 AM
Airstream comfort for Generals qqq Our Community 5 11-17-2003 06:56 PM
front couch comfort rcaldwel Airstream Trailer Forums 7 11-04-2003 11:15 AM
