Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 06-09-2021, 05:44 PM   #1
1977 24' Argosy 24
Chester , Connecticut
AC Compressor Brackets
So as I prepare to take “PHAT Amy” my 1977 Argosy Motorhome down to the outer banks late June, I began to work on the ac and found that I don’t have the front nor rear ac compressor brackets. I have been looking everywhere and can not find them. Any ideas?
Cdellarocco is offline   Reply With Quote
Old 06-13-2021, 06:27 AM   #2
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Is it on a 454. You might find the same set up or very similar setup on an old scrap Silverado or breadtruck or try RV Salvage people in Arizona
Not sure if the parts were the same across all years, but this old post from Brad might help
This might help you identify what you're looking for. Believe it or not I found that the 14100871 and 14100873 brackets might be available here in Pasadena.
Boom Sounds is offline   Reply With Quote
Old 06-16-2021, 10:45 AM   #3
1984 32.5' Airstream 325
Gainesville , Florida
I had a similar problem (454 in a 84 325) except mine had cracked. I could not find a similar item anywhere. There appears to be several variants that look close but won’t fit. I ended up having it rewelded. Sorry - not much help, just thought I’d mention the variability so you don’t get caught out. Good luck!
Shinytoaster is offline   Reply With Quote
Mounting Brackets for Folding Table?? Navigator Cabinets, Counter Tops & Furnishings 38 04-25-2008 10:50 PM
Need Window Awning Brackets RBolton Awnings 3 08-01-2007 12:13 PM
Need bunk bed brackets Safari Tim Cabinets, Counter Tops & Furnishings 8 05-01-2007 11:20 PM
Awning Brackets - How to Attach to Trailer ? Mike Rhodes Awnings 1 07-04-2006 09:29 AM
Attaching Awning Brackets Mike Rhodes Awnings 7 10-30-2002 07:35 PM
