Hello classic MH forum members.
I'm in the process of renovating my 85/86 345.
My current project (no pun intended) is to upgrade the electrical system to accommodate accepting power from a 50 amp source. In addition to replacing the 30 amp land line with a 50 amp cable, I need to add a fourth slip-ring to the cable reel. This fourth slip-ring will allow connection of the second 120 VAC circuit from a 50 amp pedestal. Changes to the switch-over relays (energized when the generator is running to switch the coach power from the land line to the generator) will also need to be addressed.
I contacted the manufacturer of the cable reel (AERO-MOTIVE Model RVA-25AT) but no joy so far with acquiring a fourth slip-ring assembly.
Have any of you performed this modification to the cable reel? If so, where did you acquire the fourth slip-ring?
Do any of you have an AERO-MOTIVE cable reel that you are not using and are willing to sell the slip-ring assembly?
This is my first post of a new thread so my plan is to attach some photos of the cable reel nameplate and of what the slip-ring components looks like. If the photos don't show up then I will seek instructions on how to post photos with my next tread.
Looking forward to your feedback and thanks for the knowledge you have already shared with the forum (which I have been devouring for the last several months).
