03-20-2020, 05:35 PM
#201
1982 31' Airstream 310
champaign
MAN! You’re kicking butt you are. Interested in how you like the tankless WH. I’ve thought about it but never pulled the trigger. We don’t leave our water heater on all the time while camping. Some do I guess. But we will turn it on about 15 mins before a shower or doing dishes etc. Unless you have full hookups, showers are pretty darn quick to save on gray tank capacity. I assume your heater will run on propane or electricity? Is that the norm?
03-20-2020, 05:54 PM
#202
"Alumi-holic"
Bartlett
, Tennessee
Girard Tankless Water Heater, propane only.
Have read good and bad reviews from users.
Appears most issues due to not understanding the system.
If water pressure is regulated, sufficient propane regulated 11” WC and temp set to 104-105 (shower mixing valve set to hot only), unit should perform admirably.
Fingers definitely crossed that I performed due diligence in my research.
[emoji120][emoji120][emoji120]
03-21-2020, 06:28 PM
#203
"Alumi-holic"
Bartlett
, Tennessee
DW wanted my work area squared away...
From this:
To this:
Salvaged all the aluminum, angle iron, screws, hinges, etc...
Piled all this on the curb for pickup:
And I’m left with this:
Finally got back to working on the coach about 1600 hours. [emoji15]
03-21-2020, 06:30 PM
#204
"Alumi-holic"
Bartlett
, Tennessee
Installed flexible stainless steel propane lines to the furnace and water heater...
03-22-2020, 06:57 AM
#205
Richmond
, Kentucky
If you keep up this blistering pace this could be a record time for a rebuild
Which would obviously put the rest of us to shame......
1975 24' Argosy Motor Home
03-22-2020, 11:50 AM
#206
"Alumi-holic"
Bartlett
, Tennessee
Turned off the TV News and just staying busy.
[emoji4]
03-22-2020, 06:49 PM
#207
"Alumi-holic"
Bartlett
, Tennessee
Secured the propane lines with insulated clamps and sealed the holes in the floor with Sikaflex.
03-22-2020, 06:56 PM
#208
"Alumi-holic"
Bartlett
, Tennessee
Set the new Transfer Switch and planned for the 50 amp upgrade.
Picked up a lot of the needed parts at the local Big Box Store. Will procure the remaining pieces at the local electrical supply store in the morning.
03-23-2020, 06:27 PM
#209
"Alumi-holic"
Bartlett
, Tennessee
Wired Shore Power and Generator to the Transfer Switch[
ATTACH]363813[/ATTACH]
03-23-2020, 06:30 PM
#210
"Alumi-holic"
Bartlett
, Tennessee
Tomorrows plan is to wire in the new load panel and connect the Transfer Switch.
03-24-2020, 04:35 PM
#211
"Alumi-holic"
Bartlett
, Tennessee
03-24-2020, 04:40 PM
#212
"Alumi-holic"
Bartlett
, Tennessee
03-24-2020, 06:20 PM
#213
"Alumi-holic"
Bartlett
, Tennessee
03-24-2020, 08:16 PM
#214
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Originally Posted by cesalie2
Walls are looking good. You are a man of many talents! I trust you wear good protection when using those nasty chemicals!?
For some reason, putting stuff back always takes so much longer than tearing it apart.
AIR #13
03-25-2020, 05:32 AM
#215
"Alumi-holic"
Bartlett
, Tennessee
Good Ventilation, gloves, mask (hard to find 🤣
Lots of cussin at the hundreds of little bits!
03-25-2020, 03:24 PM
#216
"Alumi-holic"
Bartlett
, Tennessee
Tested New 50 Amp Shore Power...Success!
Incorporated Mayco’s idea to use the city water connection to fill the fresh water tank and an overflow feature:
Now that the fresh water fill door is not being used...turned it into the new shore power inlet...
Repurposed some more aluminum from the pantry removal to cover the original Airstream jagged hole for the fresh water fill.
03-25-2020, 03:25 PM
#217
"Alumi-holic"
Bartlett
, Tennessee
The test of all the outlets and running both air conditioners at the same time was successful.
03-25-2020, 03:28 PM
#218
"Alumi-holic"
Bartlett
, Tennessee
Covered up some holes in the new coffee station area using aluminum from the old pantry.
03-25-2020, 03:32 PM
#219
"Alumi-holic"
Bartlett
, Tennessee
Remember the original refrigerator vent hole?
Yep, gone...
Note: starting to run out of old aluminum from the pantry.
Still have to build a box above the Inverter and converter for the refrigerator to rest on...thankfully still have one large piece of aluminum from the pantry.
03-25-2020, 04:37 PM
#220
"Alumi-holic"
Bartlett
, Tennessee
Stripped a little more vinyl wallpaper between tasks...
WC door
Hallway outside shower
Wow!
