01-26-2017, 04:54 PM
#121
1966 22' Safari
1954 22' Flying Cloud
Saline
, Michigan
Almost done, them to polish
01-28-2017, 07:18 PM
#122
1966 22' Safari
Saline
, Michigan
Rebuilt the H-20-2 door handle and built a new threshold. Need to install screen on the door , polish hinges and try to install door.
01-29-2017, 07:46 PM
#123
1966 22' Safari
Saline
, Michigan
Originally Posted by goshawks00
Thanks Tim... when I took the wheel wells in to the HVAC guy we went over the profile of them and I made sure he knew about there was was a width difference. I moved the frame up closer to the house and onto the pavement... wow was that full use of the 'art' of hillbilly engineering! Starting to box the frame and will be talking to Colin today about a new axle.. Will be going with a torsion , but try to maintain the original height. Other important mods will be a 'Natures Head' comode, and a bigger grey tank now that there will be more room. Where are you at with your FC ?
Barry
You
03-01-2017, 06:13 AM
#124
1966 22' Safari
Saline
, Michigan
A Cloud named 'Spoon'
You
After a month off while in Florida, I'm finally back working on Spoon. Picked up the new panel from my local metal guy and have cleoed it in place. The old panel had holes where the PO had hung something from it so needed replacing. I made the panel but didn't have the ability to put the rolled edge on it. Looks great now just needs bucking on. I also got the door in a door installed with the new hinges. Will add pics today.
03-24-2017, 09:36 AM
#125
1966 22' Safari
Saline
, Michigan
Finally back on Spoon , after to much time away the new front panel is bucked in
03-25-2017, 08:59 AM
#126
On adventure with H&G
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
Nice! I am doing that panel and the other curbside panels the next couple weeks. Love to see the progress.
--Matt
Too many trailers, not enough time.
04-07-2017, 11:57 AM
#127
1966 22' Safari
Saline
, Michigan
Slowly moving forward, the wiring in the front is roughed in, the cork rib insulation for thermal separation is done. The front cap is finally up, so I'll begin to make patterns for the wood end caps. Feel like I'm beginning to round a corner.
04-11-2017, 11:17 AM
#128
1966 22' Safari
Saline
, Michigan
first rough in for front end cap
04-11-2017, 12:16 PM
#129
1958 26' Overlander
1966 28' Ambassador
Lansing
, Kansas
That looks fantastic. What type of wood are you using?
--Matt
04-12-2017, 05:29 AM
#130
1966 22' Safari
Saline
, Michigan
I'm using 1/8" Baltic birch , the whole interior will be wrapped in it. BYW glad to see you back at it!
05-01-2017, 05:46 PM
#131
1966 22' Safari
Saline
, Michigan
We finally got the rear interior whale tail panel hung now to Mach up the panels. The front wood cap is all up with two coats of varnish, will try and get a pic tomorrow. It's been hard to get much done with spring here. Gardens, grass, camping etc then a little each day on Spoon.
05-02-2017, 03:30 PM
#132
1971 27' Overlander
Jackson
, Tennessee
Enjoying following your progress - great work!
Where did you find the 1/8" Birch? I'm having trouble locating a source.
Alan
05-02-2017, 06:43 PM
#133
1966 22' Safari
Saline
, Michigan
Johnsons in Charlotte
05-03-2017, 10:48 AM
#134
1966 22' Safari
Saline
, Michigan
Front end cap done , I like the wood grain!
05-03-2017, 11:28 PM
#135
1966 22' Safari
Saline
, Michigan
Slowly rough fitting the rear wood
05-04-2017, 08:01 AM
#136
1958 26' Overlander
Battle Ground
Birch end panels
Really like the birch panels. How are you attaching them on the long edge? Last photo looks like there is a liner underneath. Details please.
thanks Harold
05-04-2017, 12:16 PM
#137
1966 22' Safari
Saline
, Michigan
I put the original metal end caps back in as it gave good support for the wood panels where ever they lined up at. I attached the upper side of each piece with just a couple of rivets to hold in place while I fitted/adjusted the next piece., working from the bottom up. Once all pieces were fitted and in place, I took them apart, and put three coats of spar on the backs, stained the fronts and added two coats on them. Once completely done they, the insides, will get one more final coat. Once dried I re-aligned each piece, and as I worked my way up, where the bottom edge of the upper over lapped the upper edge of the bottom piece below it, I drilled and riveted the overlap every 5" 3/8 ' in from the edge. Clear as mud?
05-04-2017, 01:23 PM
#138
1966 22' Safari
Saline
, Michigan
That was 3/8" from the edge. , and I used 5/32" pop rivets.
05-04-2017, 02:30 PM
#139
1966 22' Safari
Saline
, Michigan
Kind gives a nice neat finish
05-08-2017, 12:42 PM
#140
1966 22' Safari
Saline
, Michigan
After a bunch of fitting -staining-and varnishing the bedroom area is done.[ATTACH]
