07-28-2019, 08:43 AM
Lakewood
Regulator
I recently piped in a duel fuel generator worked great for two trips last weekend would not run off of f propane auxiliary port as it has in the past. Worked fine on gasoline. Hooked up my grill to same port as usual I lite grill and then checked stove inside very low flame. Thoughts.
07-28-2019, 08:48 AM
2018 27' Tommy Bahama
Marana
Low propane level?
Bad regulator or transfer switch?
Hose issue under the AS?
Hose leak? They do go bad but hope they last longer than 3 years. Any smell?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
07-28-2019, 09:03 AM
Lakewood
Originally Posted by UncleBad
Low propane level?
No smell. Transfer switch? Is it part of the regulator / tank switch over ?
07-28-2019, 05:52 PM
Marana
Do you have dual propane tanks? The transfer switch sits between then and is used to switch to a full tank.
07-28-2019, 06:55 PM
2017 28' International
Jim Falls
, Wisconsin
Ok. I’m going to be real low tech. I had the same problem. I took off the connector and found there was a rock that got lodged in it when I forgot to put back the cap. Might want to take the end piece off and just check for any obstruction.
But first make sure your tank is full
08-31-2019, 04:16 PM
2018 22' Sport
San Antonio
I have a dual fuel Champion generator. It worked fine with propane for two months. Sat idle for a couple of months, then wouldn’t start on propane. Started on gas just fine. I’m thinking my regulator is damaged. Any thoughts.
09-01-2019, 04:25 PM
Marana
Anything is possible. Did the regulator get damaged?
Which regulator are you using?
Double check you did t run out of propane and double check the starting procedure your using since you have not used it for two months... [emoji3]
11-08-2019, 09:43 AM
2018 22' Sport
San Antonio
Turns out it was a damaged regulator. Champion replaced under warranty. Have since purchased backup regulator for redundancy as well as backup battery. Very happy with Champion service.
11-08-2019, 02:50 PM
2019 19' Flying Cloud
Canyon Country
I had similar problem until I realized that I had to take off the regulator hooked to the grill and bought a long propane hose and hooked to the grill. Solved it.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
LP Regulator
PatCrusse |
LP Gas, Piping, Tanks & Regulators |
27 |
05-15-2004 01:22 AM |
Marshall 250 regulator failure
nickcrowhurst |
11 |
04-18-2004 07:08 AM |
Dual Fuel Gas regulator
thenewkid64 |
5 |
03-12-2003 02:26 PM |
Grand Hall Ent. gas regulator recall
53flyingcloud |
0 |
12-23-2002 07:29 AM |
Pressure Regulator
pjtaia |
4 |
09-24-2002 07:26 PM |
