06-25-2019, 01:25 PM
#21
2012 25' FB International
Trent Woods
, North Carolina
Ever since we found these things, my feeling has been that the Easy Start will extend the compressor life; just listen and feel to the compressor start after installation. Not to mention the advanced protection. In for a penny...put them on both.
Larry
06-25-2019, 02:06 PM
#22
2019 30' Classic
Cary
, North Carolina
Curious what this does to the 3 year warranty? I was told by Colonial that adding an Easy Start will void the warranty of the A/C so we opted out of doing it prior to pick up if our new 2019 Classic.
Thoughts?
By the way...totally agree with the $100 per hour rule and the effort to climb up on the roof, etc. etc.
06-25-2019, 02:08 PM
#23
Trent Woods
, North Carolina
Thoughts?
See my post above....
Larry
06-25-2019, 02:12 PM
#24
Don McKelvay
1994 34' Limited
London
, Ontario
Originally Posted by Hans627
I contacted Micro-Air and they will be selling and installing the EZ Start at Doswell. The price for installing one is $135 and for installing two is $150. Of course each EZ Start unit is about $300.
I'm trying to decide if I should just get one or two (one for each A/C). Pros and cons? Any thoughts?
Thanks!
Correct, except the price for each EZ Start is $274 (down from $300) and, there is an installation kit that is another $9.89. Sounds like a really good idea especially as it may extend the life of the compressor. I plan to get one - but wish we had a second AC as it is still too warm in the bedroom of our 34 footer and would certainly then get a second EZ Start. As we have a Honda 2000 I am also going to get the generator bonding plug for $9.89.
Progressive Industries used to sell something similar but for unknown reasons no longer have them. May be a good idea to pre-order the EZ Start as I heard they ran out of them in Salem.
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
06-25-2019, 02:43 PM
#25
2009 25' FB International
2018 27' Globetrotter
Tavares
Thoughts?
FWIW the following is an excerpt from the Micro Air website under warranty section:
If, during the air conditioning manufacturers warranty period, your air conditioner experiences any compressor motor failure not covered by the manufacturers warranty and caused by the EasyStart 364, Micro-Air will, at its option, repair or replace your compressor motor or rooftop air conditioning unit.
The warranty will only be effective during the original manufacturer-supplied warranty period for the air conditioner and shall not exceed the period of the Micro-Air two-year limited warranty. The remedies of repair or full replacement at Micro-Airs discretion, shall be the sole remedies for any warranty claim. Replacements will be made with the same or comparable compressor motor or an entire unit of equal BTU capacity. The Purchaser must notify Micro-Air of any defect or malfunction in writing delivered by overnight delivery or certified mail and received within the warranty period in order to secure repair or replacement of the product. The Purchaser must return the damaged air conditioning unit to Micro-Air or its agent at the Purchasers expense so that it is received within one day of the expiration of the warranty period.
06-25-2019, 02:49 PM
#26
Tavares
What does the generator bonding plug do?
Thanks!
06-25-2019, 03:27 PM
#27
1967 26' Overlander
Bugtussle
, Oklahoma
Thanks!
There is no downside to having an EasyStart on both AC units. It is just a matter of one's budget and how you want to allocate your funds.
06-25-2019, 07:55 PM
#28
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake
Labor
I would negotiate the labor rate.
Micro-Air if at Hershey or scheduled RV shows often sell at a factory fair price and include the install if your Trailer is there.
Airstream has to pay their techs but I would still ask. Seems like $600 for both not each?
Ours was not that much at our Airstream dealer with a brand new install.
06-25-2019, 08:33 PM
#29
2019 27' Globetrotter
McHenry
Thanks!
Its used to connect the neutral and ground on inverter generators so your EMS doesnt spit an error for floating neutral.
https://rvpower.southwire.com/produc...g-model-44400/
Works like a champ!
2019 27 Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
06-25-2019, 08:58 PM
#30
2018 25' International
Washington
, Utah
It can be worse!
I contacted AS of Las Vegas and they wanted $750 installed so I guess the JC is not as bad as one might think!
06-26-2019, 01:29 PM
#31
2008 23' Safari FB SE
2018 27' International
Okemos
, Michigan
Warranty voided???
By chance did you verify the Easy-start will not void the AC manufacturers warranty? I had heard that the warranty is voided by this modification. I think it is a good modification but i am waiting until my warranty expires to install it. I would love to see confirmation the mfgr will continue warranty after this modification. Thanks
06-26-2019, 02:08 PM
#32
Overkill Specialist
2020 30 Globetrotter
2014 23' International
Dadeville
, Alabama
On MicroAir website they state that the install should not affect manufacturers warranty. They also state that if you have a problem deemed to be caused by their system they will repair or replace your unit.
http://www.micro-air.com/knowledgeba...ctory-warranty
06-26-2019, 03:07 PM
#33
2020 Classic 33
Box Elder
, South Dakota
The voiding the warranty myth. Federal law states that for a warranty claim to be denied by the manufacturer they would need to prove that the third party product contributed/caused the issue. So if the MicroAir should explode or surge 1000volts through the system then Dometic isn't going to pay a warranty claim. If the fan motor dies or the system springs a leak of the compressor gas they would be on the hook for the repair if it is covered under warranty.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NŲVPN
06-26-2019, 03:29 PM
#34
UnklJoe
2015 28' Flying Cloud
Box Elder
, South Dakota
The 62nd WBCCI International Rally (for Airstreams) is being held July 20-27, 2019, in Doswell, Virgina. There will be LOTS of vendors exhibiting there along with all the other fun things to do.
As suggested, if you are going to be there, it would be an excellent idea to contact MicroAire and get on their list for installs (to at least be sure they have enough EasyStarts to accommodate you).
06-26-2019, 04:40 PM
#35
2019 30' Classic
2021 Atlas
Charlotte
, North Carolina
MicroAir also offers a 'DoubleDown' warranty for $25. It removed the 'at their option' and makes it clear that they will cover AC warranty issues if Dometic does not becuase the Easy Start was added. Getting 2 installed in Doswell. Added the DoubleDown on both. Cheap insurance and removed any 'warranty worries'.
Interestingly enough we bought our 2019 30' and the salesman did not know what they were and stated adding them would void the warranty after checking in with others at the dealership.
06-26-2019, 11:31 PM
#36
1993 21' Sovereign
Seattle
I'm almost 72 and my wife is almost 69. We installed an way start. I just had back surgery so we looked at the schematic that matched our 25 year old penguin 1. She climbed up on to the roof and I stood on the ladder. She did the wiring and connections. I sort of supervised. We finished and took a trip to a state park where we did our 5 restarts. No problems at all.
06-27-2019, 12:15 AM
#37
Salem
, Oregon
Originally Posted by Rgentum
At last year's International Rally, in Salem, OR, Micro-Aire installed them for free --- $295 parts & labor, as I recall. I imagine they'll do the same at this year's Rally, in Virginia. In Salem, they installed all the ones they brought within a couple of days & then drove back home. If you want one, get your name on their list early.
Hi, I live in Salem, Oregon. I did not attend the rally. I live six miles from the Fairgrounds. Micro-Air came to my house and installed my unit for free. $300.00 labor each is outrages.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
06-27-2019, 04:28 AM
#38
GLCMRANGER - Sue
2016 25' International
Littlestown
, Pennsylvania
JUST DO IT!! It takes more than 15 minutes to install. And they'll do it right since JC installs a lot of them....
06-27-2019, 12:22 PM
#39
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
If you don't feel comfortable doing it, then yeah, pay the money. I did.
You didn't buy an AS being you were going to cheap.
Never understood people using the word cheap when they own an AS.
06-27-2019, 01:39 PM
#40
2023 27' Globetrotter
Pleasant Garden
, North Carolina
I'm not sure what your second sentence means but I just thought it would be a good idea to have it done while it's at the factory. Paying a reasonable price for installation is ok by mean, I just wasn't sure what was reasonable.
