Originally Posted by CAV
I just saw Command Velcro strips for hanging picture frames. Can you use Command products on inside aluminum?
My FC has a lot of 'Command' hooks all over the place, but not on the Aluminum. Why?
Because the walls are curved, and the hook backings are straight.
Velcro can be used on the aluminum per se, however............
The DHC-5 Buffalo aircraft uses it by the 'ton' for hanging padding and such. But......The aluminum structure is coated/protected by such treatments as: alodine, epoxy green primers, and then the Velcro is glued onto the frames using industrial strength contact cement; not the bare Aluminum.
I cannot advise you on using on bare Aluminum.
