One aspect of the newer Airstreams that I really like are the sewer hose storage units mounted on the belly pan just aft of the wheels. If you're not familiar with what they look like they are simply a 7 ft length of 5 inch PVC pipe plugged on one end with a screw cap on the other. For sanitary reasons, I like the idea of keeping the sewer hose separate from my other hoses, extension cords, and other cables. This would also give you more room in the bumper storage area.
Has anybody done this mod to a vintage trailer?
__________________ Sterling - 1972 Sovereign Intl (RB) Eddie - 2003 Ford Excursion (6.0L PSD) Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2 Airstream Life Contributor WBCCI 4CU #5661/AIR #5661
These were mounted by the PO. I was told it was used to haul their flag poles. Access is only from the curb side on mine so I doubt they stored the sewer hoses. My flag pole was to long to fit in it. Need to get some that will. I just got my Sewer Solutions so am getting rid of all but one emergency slinky. Yipee!
Joe
Joe
Hi - we are new to this and have begun a total restoration of a '56 Caravanner. We are putting in all new plumbing and tanks, etc.
Here's the question: What is a SEWER SOLUTION??
LuckyLindsy,
You can find out what a Sewer Solution is on their web site...
One aspect of the newer Airstreams that I really like are the sewer hose storage units mounted on the belly pan just aft of the wheels. If you're not familiar with what they look like they are simply a 7 ft length of 5 inch PVC pipe plugged on one end with a screw cap on the other. For sanitary reasons, I like the idea of keeping the sewer hose separate from my other hoses, extension cords, and other cables. This would also give you more room in the bumper storage area. Has anybody done this mod to a vintage trailer?
Hi Mike:
Yes, the factory did. These storage tubes were optional factory accessories on many vintage Airstreams of the Fifties and Sixties. They often were installed on trailers that had the "International" upgrade package, sometimes crossways near the axle(s) and sometimes lengthwise partially within the belly skin. Airstream undoubtedly got this idea for their "new" trailers from their older trailers. There's never much new under the sun.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
Well this only proves that you learn something new everyday. I can honestly say I've never seen a vintage trailer with this feature.
Nice job, 87!! Looks great.
Sewer Hose Carrier. Since I raised the undercarriage a couple of inches there is plenty of room for a 4” plastic well casing section (stronger than regular PVC) mounted crossways just behind the black tank. Made mounts out of 1/8” X 1” aluminum strap and secured them to the frame. I used stainless steel hardware. Both end caps are held on with bungees.
Sewer Hose Carrier
Curb Side Detail
Driver Side Detail
Dennis
I've seen these on a bunch of rigs. One feature to design in would be a wider opening at the end. The problem is that many of these are designed to hold the hose, but not the fittings on the hose, so folks have to remove the fittings in order to store the hose.
Lynn
Lynn:
The mod below takes care of that (the trailer fitting, anyway).
The 18" or so connection you see on the street (driver) side termination is actually a slip-on type of a PVC union. The ID of the union is a bit over 4.5", so a 45 degree clear Camco type connector stores in the pipe storage along with the slinky. I leave the Thetford/Valterra crossover on the sewerage termination. The other end of the hose hase an EZ fitting on it which also fits into the storage PVC pipe. I have about a 3" slope on the PVC and a small hole drilled in the bottom of the curb side so any entrapped water drains while on the road.
Driver Side
Curb Side
Dennis
Driver Side
Curb Side
Dennis,
Is that a coupler where your brackets screw into the tube or is it just a sleeve? I like that idea. It gives additional strength for the mount and allows a short screw to be inserted that will not protrude into the tube and snag the sewer hose. Also, did you make the brackets or did you buy them?
Dennis,
Mike:
The driver side is part of the slip-on compression union (larger ID) - the curb side is just a "shortie" coupler that I sanded the stop out of - you're right, it serves for additional strength and the screws do not penetrate the 4" PVC pipe and therefore do not snag anything.
Brackets are home made out of 1" X 1/8" Aluminum flat bar.
I'm contemplating mounting a piece of 6" PVC just to the rear of the 4". I have a collapsable alluminum step ladder (3" X 5" X 7' long when folded) that would travel well there.
Dennis
