Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Bumpers & Bumper Storage
Old 06-18-2006, 03:09 PM   #1
wacnstac
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Airstream 1979 bad rear bumper design
I'm in the process of trying to rid my AS of mice. After filling in the open ends of the frame by the tonge with expanding foam (what were they thinking?), I took off the rear bumper to see what was going on there. Some more poor design. Originally I had foam filled the hole where the main power cord goes into the rig. After further inspection, I found there to be a huge gap behind the black plastic pan. If it was solid steel behind that it would be nothing to worry about, but it isn't. I filled that in as best I could and filled in the gap underneath the plastic pan as well as filling in the frame ends in the back. This whole area is just a bad design. Water entry is another big problem back there (one I think I have licked). I'm thinking about taking out the black plastic pan all together and sealing from there but I'm not sure how to get it out of there. Even with the bumper off it doesn't seem to want to budge. I had already drilled out the rivets hodling it in. Thoughts, ideas....??
wacnstac is offline   Reply With Quote
Old 06-18-2006, 05:24 PM   #2
lebolewis
FT RVing
lebolewis's Avatar
Profile:  1976 31' Sovereign
A place w/low Humidity , FT RVing, north & south
Mice and Rats
My experience has been that Mice and Rats are only interested in occupying places that they can get food. Eliminate the food.....you eliminate the rodents!! Bill
lebolewis is offline   Reply With Quote
Old 06-18-2006, 05:39 PM   #3
wacnstac
Images: 41
No food on board. They want a place to nest. All food is entirely removed from the trailer upon leaving except for canned goods which they cannot smell. The frame rails are a mice highway.
Old 06-18-2006, 06:19 PM   #4
lebolewis
FT RVing
lebolewis's Avatar
The mice are getting food within 100 ft of your trailer, for sure! Eleminate the food....no mice! Dog/cat food is very often the culprit. Bill
Old 06-18-2006, 06:26 PM   #5
SafeHarbor
Round on both ends
SafeHarbor's Avatar
1975 28' Argosy 28
Rutledge , Georgia
Hi, Wacnstac,
On mine, that bumper stays closed. The power and water inlet are on a hose reel with a door just aft of the left rear wheel. The reel is under the streetside bed if you have twins.
Also, mine has rubber boots where the hitch triangle goes into the shell.
My Excella came from Grand Rapids, by the way.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 06-18-2006, 06:27 PM   #6
biglarry62
Profile:  1973 24' Argosy 24
Del City , Oklahoma
I work in a feed mill and we always have mice. Mice will continue to eat through the spray foam unless you embed it with steel wool . Larry
biglarry62 is offline   Reply With Quote
Old 06-18-2006, 07:13 PM   #7
wacnstac
Images: 41
No food except what they can find out in the wild. That bumper door does normally stay closed but there is of course the rather large hole that the land line power cord goes through which gives them easy entry.
Old 06-18-2006, 10:11 PM   #8
Frank S
Frank S
Profile:  1973 27' Overlander
peoria , Illinois
Hi wacnstac--I always clean out all food not in a can or jar, and set 2 mouse traps in the front, and 2 in the rear bath, on newspaper on the floor, baited with peanut butter. Get a mouse now and then--usually before they have time to do much damage. When I'm ready to roll I collect the traps, seal them in a zip lock bag, store the bag, trash the newspaper, and I'm ready to go. Good hunting.--Frank S
Frank S is offline   Reply With Quote
Old 06-19-2006, 05:25 AM   #9
wacnstac
Images: 41
I have had traps set as well while I'm gone. Same deal with peanut butter and have caught a few now and then. So I guess technically there was food in the trailer (bait on traps). Now to hijack my own thread and get it back on topic, I'm trying to seal off all openings to mice from the outside and the rear bumper is a bad area IMHO. Anybody got a better solutions what what I did with the foam?
Old 07-06-2006, 08:15 AM   #10
wacnstac
Images: 41
Well after lots of expanding foam in the rear bumper area and in the frame openings near the tongue I seem to be mouse free (knock on wood). I've also setup the 5 gallon bucket trap outside and already taken a few victims that way as well.
Old 07-06-2006, 12:37 PM   #11
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
wascnot,
I thimk i would try to dig out all that foam crapand start fresh ,its hard to know what yo hav to work with with all that stuff sprayed everywhere.just a suggestion.
good luck ,mice are a pain!
Scott
scottanlily is offline   Reply With Quote
Old 07-06-2006, 01:15 PM   #12
wacnstac
Images: 41
I'm the one who put all that foam in there to keep the bastards out. With the rear end design as it was they could get in all sides of the black plastic storage box (including in front of it, under it, and beside it). Now they cannot.
Old 07-06-2006, 02:49 PM   #13
beckybillrae
beckybillrae's Avatar
Profile:  1986 31' Sovereign
Schererville , Indiana
I just had my bumper apart due to a loose clamp on my soil pipe. There was a huge rat's nest under the plastic liner. The liner came out after removing the rivets (like you have already done). I did have to give it a good yank. You probably have it stuck in there because of the foam. It also has the springs for the lid holder in the way, so maybe that's what you're hanging up on. I talked to Ron from South Jersey RV today about a new plumbing part I needed & he suggested just getting rid of the plastic liner. He says it's a perfect place (between it & the case it sits in) for mice & rats, etc. It's a pretty good idea, because then you can keep an eye on your dump pipes in case any of the clamps come loose. I caulked everything that would let a mouse enter & also painted the metal piece in the back of the trunk to prevent any further rusting.
Becky
beckybillrae is offline   Reply With Quote
Old 07-06-2006, 07:22 PM   #14
wacnstac
Images: 41
Becky,
I was wondering if that thing would come out entirely and really thought about ripping it out before I foamed it in. Does anyone know if it is solid metal behind it? Or are there holes in the metal behind it that would have to be filled? If I ever have a problem back there again, the thing is coming out.
Sale of Airstream excelladep Our Community 9 03-12-2005 03:32 PM
2002 "Deam" Designed Airstream. Andy R Community Polls 43 12-10-2003 09:18 PM
Airstream T-Shirts jcanavera Our Community 15 08-15-2002 10:14 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
