Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Ambassador > 1961 Ambassador
Old 07-31-2007, 08:40 AM   #1
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Any other 1961 Ambassador owners?
Thanks to jcanavera, we now have an official folder in the Ambassador sub-forum for 1961 Ambassador trailers. Are there any other '61 Ambassador owners out there? Feel free to share information about your restoration work and photos of your trailer in this sub-forum.
We heard about our '61 trailer from a "little birdie" on the forum. We went and checked the trailer out in person and it was love at first sight! The trailer was used as a storage shed for the past 25+ years. It contained about 2,000 pounds of trash and debris so the trailer had sunk into the ground over the years. It took us two days to prep and remove the trailer. The trailer needs a lot of work but we are looking forward to it!
Name:	As found curbside.jpg
ID:	42228   Click image for larger version
Name:	As found front.jpg
Name:	As found rear.jpg
ID:	42230   Click image for larger version
Name:	As found streetside.jpg
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
Old 07-31-2007, 08:45 AM   #2
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Congrats! Looks like you have a good candidate that you added to your fleet. How's the inside look? Judging from the photos, everything looks to be in place. How about some more pictures?
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 07-31-2007, 01:03 PM   #3
Ken J's Avatar
Profile:  1958 26' Overlander
Tijeras , New Mexico
Cool - keep us posted on the progress with pictures.
1958 Overlander
Ken J is offline   Reply With Quote
Old 07-31-2007, 02:25 PM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Looks like you have your worked cut out for you!
I have a 1960 Ambassador, not a '61 but close!
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 08-09-2007, 11:58 PM   #5
LHall's Avatar
Profile:  1962 28' Ambassador
Phoenix , Arizona
62 Ambassador here
Hello we just recently purchased a 1962 Ambassador, close to yours in age. Yours is the same configuration on the outside as ours. I have some pictures posted as well. I am curious about the spare tire bracked on the back bumper. Is that original or home made?
LHall is offline   Reply With Quote
Old 08-10-2007, 08:26 AM   #6
Overlander & Sea's Avatar
Profile:  1961 26' Overlander
1963 19' Globetrotter
Gulfport , Mississippi
Images: 18
What a great find! We have a '61 Overlander that was Ohio built. I'm there are many similarties between the two. We just replace the AC, which looks just like the one in your picture, and the orginal hot water heater, both were in working order. Can't wait to see the pictures of the interior.
Rick & JJ, teenage sons Tommy & Will
1961 26' Overlander International Land Yacht
WBCCI #9275
Overlander & Sea is offline   Reply With Quote
Old 08-10-2007, 08:39 AM   #7
yukionna's Avatar
Images: 18
The spare tire on the back bumper looks to be home made as the rear license plate bracket was moved from the center to the left side to accommodate the spare tire. It is not a good practice to store the spare tire on the back bumper so we plan on removing it and locating it elsewhere up front. I also noticed that there isn't a rear storage compartment on this trailer.
WBCCI Region One
Old 08-10-2007, 08:47 AM   #8
yukionna's Avatar
Images: 18
I will post interior pictures shortly now that the trailer is cleaned out. There was 2,000 pounds of debris stored in the trailer that took us a few weeks to clear out.
Do you have any photos of your trailer you could post?
WBCCI Region One
Old 08-10-2007, 09:29 AM   #9
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
The 61 on the vintage photo site looks the same as you discribed.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 08-10-2007, 10:55 AM   #10
yukionna's Avatar
Images: 18
On further investigation, I believe the vintage photo site has made a mistake -- that is a photo of a 1960 Ambassador. The serial number of that Ambassador posted to the 1961 Ambassador section of the website is: I 28 0 136 T, which identifies it as a 1960 Ambassador, not a 1961.
This is further verified when you look at the serial number format and ranges for the Ohio built 1960 and 1961 Ambassadors.
1960 serial range/format: 28 0 082 T to 28 0 195 T
1961 serial format: 28 1 NNN T
WBCCI Region One
Old 08-10-2007, 11:56 AM   #11
Phoenix , Arizona
Images: 62
I think you are correct. I did not look at the VIN on that unit, but it does seem to be in the wrong section.
The setup in the rear does seem to match yours. I wonder if that was a popular modification done by the owners or was it an option from Airstream?
Richard
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 40 10-28-2009 08:07 AM
1961 Bambi '16 (Serial #16TDSS1728) Andy R 1961 - 1963 Bambi 20 05-14-2007 01:28 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 10:03 AM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 9 10-08-2002 05:08 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 01:40 PM
