Were you with the AS Viking Caravan? We weren't with them but took the ferry over with them. Also ran into them multiple times during our two months in NF.
No, but I remember seeing a large AS caravan on the highway from St John's to Corner Brook, sometime in late August.
Its rated @1800W per hour. So essentially same as wall outlet.
In above example, 20-->100% would be ~35 hours and ~5 gals of gas.
Here's the thing. If your using a generator with an EV TV it's only going to be for emergencies. In which case you only need to get as far as the next charging station. So way less charge needed.
I replaced my stock Bosal hitch with an aftermarket Draw-Tite. It is technically rated for 750 lbs of tongue weight, but the vehicle manufacturer limitation should still be observed at 500 lbs. It does give a higher factor of safety, though. It is also capable of handling weight distribution.
Wondering if your rig is the same? Thanks for any updates or pointers.
