01-25-2011, 12:36 PM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
What to do? Floor rotted.
I just gutted my 75 Trade Wind. The floor is fine except the streetside front. Do I replace the entire panel or can I splice in a panel.
01-25-2011, 12:50 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
does not look all that bad to me. First thing is to fix the leak and be sure it is dried up. If you have the sofa in the front you might even be able to just put a piece of plywood over what is there (once it is bone dry) If it is rotten you might be able to drill some holes and treat it with the wood restorer epoxy. And If you need to take a piece out it looks to me like you could just put in a smaller patch instead of doing the whole front. If I did the whole thing I would want the belly pan off and the interior walls cut open to access the elevator bolts in the channel.
01-25-2011, 12:56 PM
1974 Argosy 26
Morrill
, Nebraska
Patch It!
I would just clean out all of the rotted wood, making sure you get it all out of the "C" channel. Cut a clean edged rectangle out and make a patch. Make sure to fix the leak.
01-25-2011, 03:18 PM
1972 25' Tradewind
McHenry County
At first glance I would agree that splicing in a new piece would be the way to go. Pretty small area.
Since its gutted pull the trim off the wing windows and check for water leaks there. Both of mine were leaking.
Also had a segment seam that had opened up and was leaking down on top of the left wing adding to the problem.
Tom
01-25-2011, 04:46 PM
1968 24' Tradewind
Oxford,
, Mississippi
I would just fix that small section. You will have to remove the lower wall sections to access the bolts in the c-channel. A very handy tool for cutting the floor along the frame rails and outrigger is the vibrating type multi-tool like the Multimaster. The kerf is very small with these type tools and you can follow down the rails without and danger. Harbor Freight has one for $39. It is was worth it's weight in gold (well not really) when I removed a couple of small rotted sections in my 68 Trade Wind.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
01-25-2011, 05:25 PM
Mesa
I went for the more expensive one from HF with the variable speed. When I got to the register the clerk told me if I got the extended warranty I would get 20% off. The warranty was less than 10% and the tool actually cost me less than if I hadn't taken the warranty. Go figure. I agree that it's a great little tool. Gets into all kinds of tight spaces.
01-25-2011, 07:18 PM
1967 26' Overlander
Winston Salem
, North Carolina
Fix leak, Patch it and carry on.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
01-25-2011, 07:29 PM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
Thanks guys. I was worried about structural integrity. I know that this is a small area but it does go from beam to beam. I was thinking I'd cut in about 16 inches by about 40 inches. That would keep the patch work under the cabinets and away from walking. I'm thinking now about just doing about 12 by 30 or so. I plan on doing a floating floor in it as well so that will spread load too.
01-25-2011, 08:00 PM
Sioux Falls
, South Dakota
I just sectioned mine. I respect people who go to more work than I did for similar results. Makes me all warm and fuzzy.
01-25-2011, 08:16 PM
1968 24' Tradewind
Oxford,
, Mississippi
If you cut the old out on top of the frame members it is much easier to properly attach the new piece. You just use self tapping floor screws and drive them into the frame. The joints where old meets new will be on top of frame members. That is where the multi tool really shines. You can stay on the rails, exactly in the middle and get right up to the wall. Can't do that with a circular saw.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
01-25-2011, 09:20 PM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
So what about flexing in between the rails? I haven't measured but there's a good 16 or more inches. To those who have patched in, is there give or flexing where the two panels meet between rails? This is mostly mute cuz it's all gonna be under cabinets, but I'm still curious
01-25-2011, 10:15 PM
1974 Argosy 26
Morrill
, Nebraska
Make a gusset
You won't be standing on that section of the floor from what I can see. When you cut the plywood to make the patch. Cut the long side with the grain that shows on the surface. I wouldn't recommend using OSB. You can also cut a gusset board the length of the opening on the long side. Make it about 3" wide, slip it into the hole and under the old floor about 1 1/2" and fasten it to the underside of the old floor. There should be a lip to lay your new piece on. It will be supported on all sides, the lip I just mentioned, the "C" channel opposite of the lip and the frame members on each end.
01-25-2011, 11:06 PM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
Thanks Twinkie. That's exactly what I was thinkin.
01-26-2011, 08:42 AM
Jupiter
You're going to hate me.
One tip - Before you obstruct any inner liners from being removed or pried up from the floor get the true condition of the outriggers & hold-downs verified. I told you you were gonna hate me.
While you are there with a gutted trailer, ease the bottom liners up and tighten (replace) the Outrigger to C channel bolts, even if it means busting open and folding down the belly wraps like flower petals. Sadly, one needs to access both ends of those bolts.
I found bent & broken outriggers without fasteners and the ones that were still there were very loose from the plywood 'crushing' over time and the iron bolts rusting merrily away for 10's of years. The more I think about my 27' 1973 the more I think its a candidate for shell-off to compensate for the beatings its taken AFTER weathering and accidents should have forced a rehab that never happened until now.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
01-26-2011, 08:54 AM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
Bottom liners?
01-26-2011, 09:19 AM
White City
, Oregon
New Member!
A Hi to everyone! Am new to this site. Been reading posts for awhile and have a first question. Is this the way to ask a new question? I didn't have a Reply to Thread and didn't see where I'd start a new question?? Really like your site and look forward to using it alot in the coming months. Thanks!
01-26-2011, 09:39 AM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
If you're using a phone app, navigate back one level, press the button in upper right corner, press the "start a new thread" button.
01-26-2011, 09:51 AM
White City
, Oregon
Still Lost!
Did what you said and didn't see any button in upper right hand corner that said anything about Start a New Thread??? Thanks again!
01-26-2011, 10:23 AM
1969 31' Sovereign
1975 25' Tradewind
Walnut Creek
You're welcome to ask your questions here until you figure it out. Hopefully someone will see em and answer. Welcome to the forums by the way.
01-26-2011, 10:47 AM
White City
, Oregon
Your Help!
Thanks for the help "Breadbug"!! Went to homepage a put in a question to the Contact Us at the bottom of the page to see if they can tell me how to post a new question. Thanks again!!
