04-25-2011, 03:48 PM
2007 28' Safari SE
Westlake
, OH
Cork Floor
We purchased our second AS last year, a nice well-maintained '76 International Caravanner. The only problem so far is that it smells musty, and as we clean and scrub to get the smell out we decided to replace the carpet. It extended through the bathroom and up the bathroom walls, and now that it's out I'm looking to replace with cork. The carpet was cut up to the cabinets and sofas. I want to use cork because 1. I like it 2. I can easily cut it to fit around the cabinets and sofas. Anyone have any thoughts? Tips? A local restoration place quoted $1800-$2000 for laminate flooring, I have to assume that was a full floor installed with cabinets, appliances, and furniture removed.
04-25-2011, 04:19 PM
Corpus Christi
Tow Air,
DIY Network rebuilt a 77 Overlander. I think I did the link right. This is the You tube video on the flooring installation. They used cork and I thought it looked pretty sharp. If I screwed up the link just go to youtube and search for DIY Trailer restoration..
Have fun!
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
04-25-2011, 04:25 PM
1985 31' Excella
Fresno
Cork has been around for many years as flooring in Architecturally designed projects. I remember discussions about it in collage in Construction Materials Class. It is a good flooring product is easy on the feet but probably net a good choice if you have large dogs that could possibly scratch the cork over time. It has sound deadening properties also.
04-25-2011, 05:01 PM
1960 33' Custom
Athens
, Georgia
I'm going with cork tile 1' x 2' glue down.
04-25-2011, 10:17 PM
1966 24' Tradewind
Placerville
We installed a 'floating' cork floor last Spring. It was 1' x 1 1/2 ' planks that clicked and locked together. Easy to cut to go around cabinets and doorways.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
04-25-2011, 10:31 PM
Tool Hoarder
West
Neil
I am also going with the floating cork. It looks really sharp, I have seen it in a couple of trailers.
04-26-2011, 06:02 AM
Ottawa
, ON
I'm surprised that you would go with a glue down, given the expansion/contraction that is bound to happen with the temperature extremes we get here in Canada...
04-26-2011, 07:00 AM
1968 24' Tradewind
Oxford,
, Mississippi
I used a "corK" heavy traffic sheet vinyl I found at a local building supply. My wife wanted cork but I wanted a seamless floor, we both won. I had the interior removed, it would have been tough if the cabinets had been in. Which brings me to my second point. There is no way I would let the restoration guys remove and reinstall the cabinets in my trailer unless they had done a lot of work on Airstreams. I'd get references. Their objective will be to get the floor done and fast. Just a thought.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
04-26-2011, 10:01 AM
1999 28' Excella
Frederick
, Maryland
The PO of our trailer installed the floating style cork. He did a very nice, pro level job. Looks great and seems to be holding up very well with the pea gravel from campsites and the sand from the beach. We added a few throw rugs for areas such as by the sink and in between the beds.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
KC3MAP
On internet forums, please research and separate the wheat from the chaff (including mine!)
04-26-2011, 10:30 AM
1985 31' Excella
Fresno
04-26-2011, 11:56 AM
1964 19' Globetrotter
South Kingstown
, Rhode Island
I used cork in our AS, not the best installation but it looks nice. I had it installed in our kitchen as a test, to learn how it works before foisting it off on clients, and bought enough for a DIY project in the trailer. Am Cork is a great product, however for a DIY install I'd recommend a floating floor. The glue down, when done right is awesome (in our Kitchen) but it was a pain for me in the trailer, and the moisture fluctuations in a trailer are significant for a "wood" product like cork. The floating floors are easier to repair as well.
Wherever you go, there you are
04-26-2011, 12:12 PM
1966 26' Overlander
Woodstock
, Georgia
Cork and Allure Cork
TRAFFICMASTER from Home Depot has a cork look vinyl plank that looks great. I have used real cork and this stuff, both are good choices and easy to put in.
04-26-2011, 12:13 PM
1974 27' Overlander
Sault ste Marie
, Ontario
A couple of years ago we put cork down and vertical tongue and groove cedar in the bathroom to replace our smelly (smoke and dog) carpet. Easy to do and smells much better.
04-26-2011, 12:17 PM
1966 26' Overlander
Woodstock
, Georgia
looks good-- nice lens too
04-26-2011, 07:23 PM
2007 28' Safari SE
Westlake
, OH
Great posts and pics. I'm going to go with floating, because I don't want to mess with the adhesive and I think it might be easier for my DIY level. Another hour today on floor prep, about 3-4 hours of staple removing and sanding and hopefully we will be installing next week.
By the way, if you want to see this old Airstream and our other one, we will be "urban camping" at Burke Lakefront Airport at the Cleveland Unit Spirit of Cleveland Rally June 8-12. 85 of 100 sites booked to date!
04-26-2011, 07:42 PM
South Kingstown
, Rhode Island
The floating is FAR more forgiving than the glue down- glue down has to have a perfectly prepared substrate.
04-26-2011, 09:31 PM
1966 24' Tradewind
Placerville
I did have one annoying problem during my 'floating floor' installation. A PO had installed self sticking vinyl tiles. When I pulled those up I had a gooey floor. So I laid a sheet of poly plastic moisture barrier down. That was tricky to as the goo would grab the poly sheet before I was ready to align it. I finally gave up making that perfect as I discovered that the plastic is so thin that once flat any folds were flat also. So I have a moisture barrier too.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
04-26-2011, 09:47 PM
1966 24' Tradewind
Placerville
I found my posts on my installation. It's in this thread...posts begining with #21. http://www.airforums.com/forums/f461...s-65213-2.html
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
05-12-2011, 12:37 PM
Leadville(for now)
Fresh Air,
I am interested in the cork flooring You put in! This sounds like the type of flooring I would like to install in My 77 Silver Streak 'Refurbish'.
Not really inclined for a adhesive/glue down type; and I had wobdered if this type of cork flooring was available...Wa-La !!
Info on sources for this flooring would be much appreciated!!
Christopher
05-12-2011, 01:20 PM
1978 28' Argosy 28
Post Falls
, Idaho
If the "musty odor" is partialy due to the carpet that was removed it likely is in the plywood subfloor. If you go to ehow.com and search for "How To Seal A Subfloor From Pet Odor" there are instructions that I followed before installing a floating laminate floor in my motorhome. It's some extra work but was well worth it in my opinion. I did not remove the cabinets etc. and it took quite a bit longer than I expected. There is alot of cutting involved and an expansion gap is needed all around. You will also need to install baseboard of some kind to take care of the gap. I love the look and feel of cork and was very close to choosing it over the wood laminate. Before you purchase get a sample and see if it will be durable enough for your needs. The samples I looked at could be scrached quite easily with your fingernail.
Good Luck with your project !
