Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > General Interior Topics
Old 08-06-2013, 06:48 AM   #21
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Originally Posted by wxbuoy View Post
Evan,
Fantastic job! I am doing the same thing so this is definitely an inspiration! Two questions: Where did you get the curved piece of wood for the base of the bed or did you lay it up and epoxy yourself. Second; Where did you get the custom fit mattresses that math the airstream curve.
Thanks!
Hi,
Thanks.
The curved bed bases were salvaged from the Queen bed base I had. They worked well in their new position I think.
I used a cardboard box to cutout a pattern to contour to the curved walls. I took this to a local Foam shop to make up custom 8 inch thick foam mattresses with their covers. (They do custom marine & RV mattresses among other foam articles.) I opted for 35 inch wide mattresses which are a little wider than the AS factory specs but closer to true Twin mattress width...
-evan
eheffa is offline   Reply With Quote
Old 08-06-2013, 08:28 AM   #22
2010 25' FB Flying Cloud
Davenport , Iowa
Evan, where did you get the roll up doors, and what size are they?
This is my end of season job, so getting the list together now.
mike
Airtandem is offline   Reply With Quote
Old 08-06-2013, 10:09 AM   #23
eheffa's Avatar
Victoria , BC
mike
They are a tambour door kit in red Oak 24 inch from here:
Tambour Door Kit - Lee Valley Tools
You might find them cheaper Stateside.
-evan
Old 08-06-2013, 11:37 PM   #24
parker10302's Avatar
Laguna Beach , California
Evan,
Thank you so much for the great photos and all the detailed information. This is a huge help and gives us an idea of what we're in for!
Nicole
parker10302 is offline   Reply With Quote
Old 08-07-2013, 06:09 AM   #25
eheffa's Avatar
Victoria , BC
Originally Posted by parker10302 View Post
Evan,
Nicole
Thank you Nicole. I'm glad to think that others might find it helpful to post stuff like this... I combed this forum for ideas before I took the plunge myself.
Good luck with your project.
-evan
Old 08-16-2013, 02:44 PM   #26
2008 22' Safari
2000 27' Safari
Asheville , North Carolina
What a professional looking job! Can I ask where you found the curved wooden end pieces for the beds? Thanks!
Suzanne
Suzmsw is offline   Reply With Quote
Old 08-16-2013, 04:05 PM   #27
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I think he mentioned something about a queen bed set they had.. look higher up the list..
it is cool for sure. wish i had the time and place, (and AS) to take on such a project.
Suzanne
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 08-17-2013, 06:23 AM   #28
eheffa's Avatar
Victoria , BC
Suzanne
Thank You Suzanne.
The curved pieces & most of the visible (finished ) surfaces were simply salvaged from the original Queen bedroom components that came with the Airstream...just kind of re-configured to their new purposes. The port side bunk had some new red Oak pieces along with the tambour doors finished in acrylic clearcoat but most of the new plywood etc. is stuff you can't see.
-evan
Old 08-17-2013, 06:24 AM   #29
eheffa's Avatar
Victoria , BC
Thanks Carl.
Getting obsessed with a project has a way of creating more time than what you thought you had ...
Good luck finding your A/S.
-evan
Old 08-18-2013, 06:23 AM   #30
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
All these restorations and modifications take lots more time than forecast.
Remember, that as far as we know, the only man to get things done by Friday was Robinson Crusoe.
Old 09-03-2013, 08:17 PM   #31
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Nice job, I like the rotating heat duct and the tambour doors under the bed.
Old 09-03-2013, 11:22 PM   #32
TinCan
graysailor's Avatar
2016 30' Classic
Very nice indeed.
TinCan
graysailor is offline   Reply With Quote
Old 09-04-2013, 02:59 AM   #33
switz's Avatar
2014 31' Classic
Great talent!
Old 09-21-2013, 08:18 AM   #34
Rollster's Avatar
Saint Augustine , Florida
-evan
Hi Evan,
We've been studying your original post about converting to twin beds and are in the planning stages of doing the same. Can you tell me what the blue material along the walls beneath the bunks is and what it's for? Also, to what did you attach the wood on the top of the bunks along the wall? I can't see framing on that side. Thanks so much! I'm getting very excited about doing this project! We are hoping to be able to reuse the queen pedestal and framing without buying additional wood; although I do love your tambour doors.
Carol
Carol, Aboard "Aggie the DreamStream"
WBCCI# 5248
Rollster is offline   Reply With Quote
Old 09-21-2013, 08:36 AM   #35
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
Well done conversion. I am wondering though if the head end of the beds could be done differently. I like to sit in bed and read, which means propping up against a head board of some sort. The curved walls don't make that too easy, although you can pile pillows I suppose. What I was wondering is if there is enough length to allow a squaring off at the head in some way, to make it more like a headboard? (Sitting here without a ruler, or I would go measure!)
I wish we had given more consideration to twin v. queen.
mstephens is offline   Reply With Quote
Old 09-21-2013, 09:07 AM   #36
Rollster's Avatar
We were just out measuring. The longest length is 80 inches, so you'd have to deduct for the curved wall. I can check when I get back to the camper. I was just thinking, like you, of using throw pillows when lounging against the wall.
WBCCI# 5248
Old 09-21-2013, 09:49 AM   #37
mstephens's Avatar
80" sounds like there is some room then. Thanks! I think I could make do with a 68" bed length measuring the flat portion from head to toe.
OTOH, I would have to consider resale value if I made the beds too short!
Old 09-22-2013, 06:23 AM   #38
switz's Avatar
2014 31' Classic
These images show the Airstream mattress details in case this helps.
File Type: pdf 2014 Twin Mattress Corner Detail 702939 .pdf (467.3 KB, 181 views)
Old 09-22-2013, 07:35 AM   #39
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Great Job
This is a great job, very detailed and excellent photo's, thanks for the inspiration.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 09-22-2013, 09:48 AM   #40
eheffa's Avatar
Victoria , BC
Originally Posted by Rollster View Post
Hi Evan,
Carol
Hi Carol,
Sorry for the slow reply. we are en route back from our last planned camping trip of the year.
Thank you for your kind comments & interest.
The blue material along the walls is high density foam sleeping pad material for backpacking. Since the heating ducts run through that space & a little extra insulation & padding for cargo under the beds would be welcome, I thought I would add that. I was thinking of adding some of this above the bed platform in a removable way ( with snaps?) to reduce the cold wall contact but now that we've been sleeping in the mountains in sub zero nights, (Celsius not Fahrenheit BTW) I'm not sure that I will. It's pretty ok as it is...
If I understand your other question correctly... The plywood decking of the bunks is attached to the walls with 1" aluminum right angle (L shaped) linear stock. I just emulated what the factory did by cutting out triangular wedges along the horizontal ( supporting) edge to allow the material to curve and conform to the curved walls & plywood. The aluminum is simply screwed to the inner skin with sheet metal screws.
Here's a pic from above.
& a pic from below
I hope those lousy iPhone images give you the information you need to make sense of that.
I was able to reuse a lot of the queen bed materials. The curved bases & laminated material in particular were very welcome; but I think you should expect to have to buy some plywood & a few pieces of oak or similar stock to finish the job.
My good wife & I very much appreciate the more useful space this new configuration gives us.
- evan
Int'l 27-twin bed vs queen; convert to queen Soul Food II General Interior Topics 6 10-27-2023 03:43 PM
Queen to twin conversion Roadtoaster General Interior Topics 9 03-09-2022 06:18 PM
FB N/S Queen to Twin Conversion Al and Missy General Interior Topics 2 12-06-2013 08:17 PM
Twin/Queen Conversion - Idea Foiled Again General Interior Topics 6 07-05-2008 10:25 AM
Conversion of twin beds to queen tslanier Cabinets, Counter Tops & Furnishings 5 01-23-2007 06:34 AM
