Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-14-2017, 05:39 PM   #1
2015 30' FB FC Bunk
Ayer , Massachusetts
Sealing the rub rail, is it important?
I noticed on a video with Vinnie's Northbay Airstream he was sealing the rub rail very carefully.
I am assuming there is a horizontal seal there? I am assuming this is important to seal/reseal when the time comes? There is a rub rail mid-height and one down low.
Thanks.
Ted S. is offline   Reply With Quote
Old 08-14-2017, 06:43 PM   #2
Iansk's Avatar
1977 31' Sovereign
Sunset Valley , Texas
I sealed mine on the top and left the bottom alone to breath, like it was doing yoga. This is on each rub rail, mid and bottom.
Ian
Iansk is offline   Reply With Quote
Old 08-14-2017, 06:46 PM   #3
1976 31' Sovereign
Oswego , Illinois
Smile
The lower rub rail covers banana wrap and side panels. Very def. seal by running sealer along top of rail, middle I don't no if cover a seam or not but I always caulk same as bottom, as under vinyl strip are pop rivets that hold rails on.
Old 08-22-2017, 03:04 PM   #4
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
The bottom rub rail is where the shell/floor/bellypan meet. The bellypan overlaps the shell which will allow water to run right to the floor. You need to caulk this area.
Matt
rugjenkins is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Rub rail sealing sarasafari Exterior Restoration Forum 3 03-14-2013 06:29 AM
blue rub rail paul k Clearcoat, Exterior Paint & Trim 0 04-27-2003 12:52 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
