Old 08-27-2017, 04:38 PM   #1
1972 25' Tradewind
East Lansing , Michigan
Leaky rivet preparation
I have a bottle of Captain Tolley's crack sealer. What is the best way to clean around the rivets before placing the sealer to them? I will check each rivet and double dose each leaker, but is it advantageous to place the sealer on tight rivets, too, as a preventative?
What about putting Tolleys sealer in all the seams before caulking them?
Any tips or recommendations will be appreciated!
SnowWanderer is offline   Reply With Quote
Old 08-27-2017, 05:57 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
SW, Yes do all seams and rivets if you want to maintain seals. The rivets and seams should be cleaned up first by using small plastic scrappers and mineral spirits. I found mine at Harbor Freight Tools. You can (and I have) put new edges on these tools by hand sanding the blade edge on a flat piece of sandpaper until edge is restored to like new condition. Then use your crack cure until it is no longer absorbed into the seam or rivet head edge. Then you can reseal all rivets and seams. Hope this helps, Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-28-2017, 06:17 AM   #3
1972 25' Tradewind
Thanks! I'll do it!
leaky leaky leaky Zellia All Argosy Trailers 8 08-07-2015 05:25 AM
White roof preparation silver 67 Roof 21 10-22-2011 08:11 PM
Vinyl tile subfloor preparation without replacement star kitty Repairing/Replacing Floor &/or Frame 7 11-07-2010 07:52 PM
Spring preparation for travel season maznblu Winterizing, Storage, Carports & Covers 19 03-30-2004 01:41 PM
Polish Preparation... trailertrash Cleaning, Stripping & Polishing 5 08-12-2003 09:42 AM
