11-19-2009, 10:07 AM
#41
2019 27' Tommy Bahama
Roseville
Originally Posted by TBRich
This is what we have now, too, just in case (see post #22)...we bought a brown door stop first, then found a nice grey one that rally looks good with the aluminum. The only difference in use is that we put it in from the door grab the other direction direction and really wedge it in. Works great!
Thanks, Terry & fricad5! I would rather buy one of these now, and not worry, than have the door fly open in transit and wish I had....
I still wonder if anyone with a newer Airstream has had this happen.... We always double-lock the door. We have some potholes in our highways that will knock your teeth out, and our door has never opened....I cannot say the same about some of the drawers
2019 27' Airstream Tommy Bahama
2011 GMC 3500HD Duramax
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
11-20-2009, 07:40 PM
#42
2000 28' Excella
Stewartstown
, Pennsylvania
I know of at least one Airstreamer with a newer wide body AS who wished he had put the "doorstop" in place. I viewed the damage from the door coming open while in transit. Also while at the International this year I saw two doors come open in the parade of the vintage trailers as they made the turn into the parking area.
11-20-2009, 10:28 PM
#43
1977 27' Overlander
Trotwood
, Ohio
I don't know if anyone has had issues with the newer trailer doors commin open but I dont take any chances with my old trailer .
We did have a lite brown rubber door stop kickin around ,I drilled a hole(1/2 wood drill) in the thick end and found a bungie cord with a plastic ball on the end to keep it tyed to the hand rail when in transit and to hang it just inside the door when not in use. We always have lock the door with a key because the PO said it had come open once when he was movin the trailer around and suggested we always keep it locked while in transit. The door stop wedges in really tight and leaves no marks on the skin. Thanks for that Idea whom ever though of it and I still have my fingers from not Whittling.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
09-08-2010, 07:02 AM
#44
FT RVing
1976 31' Sovereign
Always searching for a place w/low Humidity
, FT RVing, N & S, E & W, & in between
"Hickies" for sale
Anyone with a lot of free time and a bandsaw ever thought of making these "Hickies" and offering them "for sale"? I would buy one! Especially if they are Airstream Blue!......Anyone? The market must be thousands.....
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
09-08-2010, 07:17 AM
#45
R n B
1965 17' Caravel
1961 24' Tradewind
Ephrata
Made mine out of wifes old cutting board. Works great.
09-08-2010, 11:45 AM
#46
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Making these would be fairly easy although each trailer's dimensions would be different so a 'doohickey' would need to be custom made for each trailer.
I really like the cutting board idea.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
09-08-2010, 11:48 AM
#47
1968 17' Caravel
Battle Ground
I liked the rubber doorstops with the bungie through them. Couldn't be much simpler, cost you less than $5 and you could make it by hand in about 5 minutes. If I ever lose my 'vintage' one, that's what I'll replace it with.
Stephanie
09-08-2010, 12:20 PM
#48
1970 27' Overlander
Houston
DooHickey?
Originally Posted by markdoane
I think that must be a doctored picture, because when I invented the 'doohickey' the patent office approved the application without delay.
They would never approve the patent if it had been invented by someone else.
Those of you that are using my doohickey without licence will be hearing from my attorney.
I hate to tell y'all but . . . its a "thingamajiger" not a doohickey.
____________
1970 Overlander
09-08-2010, 01:11 PM
#49
FT RVing
1976 31' Sovereign
Doohickey
When the women out there chime in, it will become a "little Thingy".
09-08-2010, 04:09 PM
#50
Sioux Falls
, South Dakota
I use one just like that to reach inside my pants and pull my shorts up while standing in line to check out at Wal-Mart.
09-08-2010, 04:16 PM
#51
FT RVing
1976 31' Sovereign
Doohickey
Ha....I've seen photos of some "Walmart Customers". Hope someone captured you in action!!
