Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-23-2014, 03:46 PM   #41
1974 31' Excella 500
Roy , Washington
Sheared screws in door lock...
I have a fun one... I just tried removed my door lock, and 1 screw stripped and two sheared off! Given that the block is pretty soft aluminum, any suggestion on extracting/drilling out the screws? I can liv with bigger screws, but afraid the drilling out process will wreck the mounting blocks...
truckirwin is offline   Reply With Quote
Old 05-23-2014, 08:28 PM   #42
There is not much body to the backside of the KT locks.
DO NOT any size drill bit except one that will barely clean out the screws.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-23-2014, 09:53 PM   #43
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
'73 Door Handle went to crap
If they broke on removal, they must be stuck big time.
The only advise I can give is obvious,,, to do your best to get those holes started dead center.
It often helps to get the broken pieces of screws filed flat, this helps finding and keeping the drill bit dead center, but it is hard to do if the piece is still in place.
Start with a small bit and work your way bigger. With a little luck the broken pieces will come loose before you hit threads.
I have found that I do better drilling broken bolts out dead center when I absolutely have to do so.
Old 05-24-2014, 11:11 PM   #44
jgp1968's Avatar
1977 31' Sovereign
Naples , Texas
[URL][/ http://www.airforums.com/forums/showthread.php?t=77534 ][IMG][/IMG]Retrofit
Sent from my XT1028 using Airstream Forums mobile app
jgp1968 is offline   Reply With Quote
Old 10-11-2015, 02:55 PM   #45
Leesburg , VA
I don't know if anyone is still following this thread over a year later, but I am in need of some help with this lock.
When I re-insulated the door I misplaced the two screws that are vertical which hold the lock in place and on the door. Does anyone know the size of those?
Thanks in advance.
cecreighton is offline   Reply With Quote
Old 06-03-2018, 06:37 PM   #46
1972 23' Safari
santa barbara , California
help
ok..been reading this thread. i know its old but. trying to take the door latch out of my 72 Safari..took all the bolts out, unscrewed the inner lock pin and...its all loose but how the hell does it come out? the post for the inner handle does not clear the inner skin. so i cant tilk it enough. and the latch does not retract enough to clear the door frame. anyone have a clue what i and doing wrong??
thanks!!!
scooterbobby is offline   Reply With Quote
Old 06-04-2018, 06:58 AM   #47
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You have to drill the rivets out where the two inner inner skins are joined. Pull the skin out enough to remove the mechanism.
Looking for door handle- help please old man listening Doors & Locks 11 04-17-2023 05:40 PM
Door Handle - Replacement for 1981 Excella dienst1 General Motorhome Topics 44 10-08-2011 10:36 PM
door handle T&Cairstream Doors & Locks 2 12-11-2007 10:58 AM
