Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Phone, CB & Ham Radio
Old 09-23-2018, 11:29 AM   #21
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Originally Posted by fulltime View Post
does it work to hook up the coax from the outside antenna to the satellite in connection on the outside of the trailer and then run the coax that hooks up to the inside receiver to the satellite out connection inside the trailer? Would that eliminate the need to come though the roof?
Different type of coax is needed - a shielded low resistant cable design for antenna use (not regular TV coax).
Also, you want your external antenna up high on the roof - at least 10’ away from the internal antenna. I had my external surecall placed at the back of the trailer.
Come down the fridge vent -> 95%+ of installs are done this way. My internal antenna is mounted right above the fridge - easy!
ID:	323426   Click image for larger version
wulfraat is offline   Reply With Quote
Old 09-23-2018, 11:37 AM   #22
Sag Harbor , New York
Welcome to the forum, fulltime!
FYI there are some more extensive Weboost threads:
http://www.airforums.com/forums/f317...ll-135215.html
http://www.airforums.com/forums/f240...er-176645.html
http://www.airforums.com/forums/f451...dy-181665.html
Also, the new search function in the blue box above works great:
"Weboost" results: https://www.google.com/search?q=Webo...=airforums.com
Cheers,
Peter
FYI
Old 03-30-2019, 04:56 PM   #23
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Update. First time out this year. We camped last week at Cannon Beach Resort RV Park and using the PDQ Connect One Sources we were able to stream Netflix through the campground WiFi. The signal dropped one time, but except for that, it worked flawlessly for five hours of viewing over a three day period including a Saturday when the campground was full. When walking the dog my iPhone WiFi and 3G/4G would be out of range of the One Source and revert to the campground WiFi and UN-amplified cell service and be minimally connected until returning to the AS.
I am very pleased with this set up.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-26-2019, 08:07 PM   #24
2018 30' Flying Cloud
New Hudson , Michigan
Do you notice any signal loss when the A/C unit is running with this setup? I was looking to do the same but wasn't sure if A/C would generate interference causing issues.?
ekbruster is offline   Reply With Quote
Old 07-27-2019, 08:59 AM   #25
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Good question. I have only needed the A/C once when in a campground near Garberville, CA two weeks ago but didn't compare signal strength between A/C on and off. I will test this on our next trip in August and report.
WeBoost Roof Antenna dougtuck Working on the Road 21 02-02-2020 09:40 AM
Weboost Interior Antenna Daquenzer Electronics & Connectivity 1 10-03-2017 01:27 PM
Weboost external antenna The Colonel Computers, Internet & Satellite 15 11-02-2016 09:50 AM
Verizon Jetpack external antenna vs. Weboost? DarrellT Computers, Internet & Satellite 13 09-07-2016 06:08 PM
Drill Baby, Drill! Mount external antenna TropicGuy Computers, Internet & Satellite 5 04-17-2010 03:02 PM
