Old 06-30-2019, 11:35 AM   #1
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Weboost antenna on plumbing vent
Hi all
My plan for every day setup is Weboost (Connect RV 65), but use the outside omnidirectional antenna from their (Drive 4G-X RV) kit. Then pull out the mast and directional antenna only when needed. I emailed Weboost and they said it would work.
Ben fussing over the outside antenna location for a while and decided to extend the plumbing vent up and use it for the antenna mount and as a point of access for the cable.
Stay tuned, work in progress!
ID:	344911   Click image for larger version
Ahroc is offline   Reply With Quote
Old 06-30-2019, 12:08 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
That vent is a mighty light weight piece of plastic. The antenna is very much "up in the wind". I would want it mounted to something very solid. When you are running down a two lane road at 55 mph (who would ever go faster .... ) and a truck comes down the other lane going the same speed, the wind blast is at least 110 mph. Of course if you are driving in Texas that could be ... errr ...140 mph.
Old 07-16-2019, 01:10 AM   #3
Ahroc's Avatar
2003 25' Safari
Keizer , Oregon
Hi Bob
I appricate your concerns but I'm going for it.
The factory vent was very NOT plumb, so I ended up doing some work inside to straighten it out. In the process I decided to change to PVC for a white look on top. I used a standard metal roof plumbing vent seal. I did use 6-32 aluminum nutzerts in the airstream skin and 6-32 stainless bolts to attach the seal. Dicor sealant under and around. I decided to use a threaded connection on top giving me flexibility to play with it.
Still in process.
ID:	346755   Click image for larger version
ID:	346757   Click image for larger version
WeBoost Roof Antenna dougtuck Working on the Road 21 02-02-2020 10:40 AM
Weboost external antenna The Colonel Phone, CB & Ham Radio 24 07-27-2019 09:59 AM
Weboost Interior Antenna Daquenzer Electronics & Connectivity 1 10-03-2017 02:27 PM
Weboost external antenna The Colonel Computers, Internet & Satellite 15 11-02-2016 10:50 AM
Verizon Jetpack external antenna vs. Weboost? DarrellT Computers, Internet & Satellite 13 09-07-2016 07:08 PM
