08-10-2015, 11:01 AM
1981 31' Excella II
New Market
, Alabama
Wanting To Replace OEM TV antenna on 81 Excella II
My original TV antenna is showing it's age and it not optimized for UHF which is where most of the HDTV stations are. I have been looking at the Wineguard Sensar IV but I know these things are cheaply built. I would also prefer something that does not have to be raised and lowered like and Omini Direction antenna but I won't if the range will be a problem. It seems like in places like FL that an Omni would be better since you have stations in every direction. With a directional antenna you have to have it pointed in one direction which means it might miss other nearby stations not in the same direction. I would prefer something rugged. The Sensar IV has exposed gears that I would assume will get gummed up and fall apart after a few years in the sun. I am looking for suggestions. Will the sensar be a pain to install in the old location?
I could keep the old unit but it is going to need some new parts. Anyone ever compared the signals between the hold whisker antenna to the newer bat wing type?
Perry
08-10-2015, 12:21 PM
2004 28' Classic
Fresno
I just replaced my antenna with King Controls "Jack" - RV Digital Antenna. Under $50 and works great.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
08-10-2015, 01:19 PM
1981 31' Excella II
New Market
, Alabama
What did you have before?
Perry
08-10-2015, 02:31 PM
1981 31' Excella II
New Market
, Alabama
OK I talked to King Jack on the phone and since I don't have a Winegard with the two square booms, I would have to use their fixed base model. The only problem there is that it does not retract and it would ugly up the roof of my Airstream. They make a version that only fits the Winegard base. The model with the base has a built in signal meter and you don't have to deal with finicky cranks for raising and lowering.
The guy I talked to seemed to know his stuff. He said their antenna has more signal than the Wingard Sensar and it is less directional. The Sensar was originally an VHF antenna and they added the Wingman to it to make it work better for UHF but that makes it even more directional.
Has anyone installed the King Jack with the fixed base?
Perry
08-10-2015, 05:32 PM
Overland Adventurer
2009 34' Panamerica
Telluride
I have 2 Airstreams, one with the old standard Sensar with wingman and the other with the Jack. I find zero difference between the 2, other than esthetics, I hate the way the fixed Jack looks..... Going back to Winegard.
08-10-2015, 06:18 PM
Mission
There are still TV signals in the airwaves?
Where we live we're lucky to have cellular service.
08-10-2015, 06:52 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
These are not cheap, but would a good choice for a no crank solution.
Winegard Rayzar Automatic - Fully Automatic RV Antenna
As I recall, the old antennas used flat lead instead of coax. That will probably need upgrading with a new antenna, as most need 12 volts supplied via the coax for the signal amp.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
08-11-2015, 07:26 PM
2012 23' FB International
Woodstock
, Ontario
I replaced the original antenna on our '89 with a Winegard in 2004. Biggest problem was getting the old base off the roof. It was stuck down with Vulkem( polyurethane). Asked for help on this forum and was told to ease the base off using a putty knife. Be really careful with the knife so as to not pierce the aluminum skin. It Is a slow process. The antenna wiring in the '89 was Co-Ax, but the antenna has flat 300 ohm wire. I believe I had to make up a new connection at the roof using the Winegard Co-Ax. We also had to rewire the booster with the new one that comes with the Winegard. We did lose the ability to connect the trailer to outside cable from the campsite supply, but I just routed new Co-Ax from the storage compartment on the driver side of the trailer when we were permanently camped in Texas.
JCW
08-12-2015, 09:08 AM
1981 31' Excella II
New Market
, Alabama
I will probably use the wingard crank up unit. I have already bypassed the trailer wiring with new coax.
Perry
08-13-2015, 04:35 PM
Glamper Girl
2008 23' International
Sunny San Diego
I have a question for those of you who understand digital signals. Time warner cable just notified me that my HOME service will now require a "smart" tv or I have to rent a box to connect my tv rather than connecting directly to the cable outlet at the wall. The TWC rep explained that there is no such thing as free tv anymore, but I'm hoping thats just sales talk to try to get me to upgrade my home service. :huh
Having said that my question is...... If I'm boon docking and use my wingard antenna will I be able to receive signal/free tv? And if I'm at an RV park that offers cable will I have to upgrade my existing tv (in the trailer) to a smart tv in order to watch local channels?
Glamper Girl
08-13-2015, 08:05 PM
1980 24' Caravelle
corpus christi
TWC sales talk.
08-13-2015, 09:08 PM
2008 27' Safari FB SE
Miami
There are actually more free broadcast stations now than before the switch to digital. Your sales rep is lying through his teeth.
In Miami where there were twelve, there are now over thirty digital broadcast stations. Granted some are junk (home shopping) and some are foreign language but the picture quality is flawless HD.
Keep your antenna.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
08-14-2015, 07:26 AM
Woodstock
, Ontario
Re Time Warner
If you have a newer TV then it will/should receive the digital signals; probably already is doing so. I live in Canada but as I recall all TV signals in the US went digital in 2008 or 2009 and we had just purchased a new TV for the AS. It worked really good in Texas except that we have to do a channel search every time we set up. We were getting a mix of analog and digital. Canada switched to Digital about 12 -18 months later, probably about the time the US analog signals were dropped.
On the flip side our cable system here in Ontario Canada required a Digital Converter for some channels about three years ago to accommodate High Definition signals which were fed through a different channel. The box kept everything the same, and we did not have to pay for it. It may be TW is doing something like that.
JCW
08-14-2015, 04:43 PM
1981 31' Excella II
New Market
, Alabama
Some cable stations are encrypted so you have to have their box or a chip in the TV that the cable company programs. You can receive over the air HD broadcasts for free. Most networks have 3 or 4 sub channels to watch.
Perry
08-14-2015, 05:03 PM
2006 25' Safari
St. Augustine
I stand behind the Winegard Razar batwing retrofit. When I spoke to them the power of the Razar is just a good but provides that on BOTH sides AND is tuned for the newer frequencies. There was an immediate improvement on my TV from the batwing.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
08-14-2015, 06:59 PM
2006 25' Safari
St. Augustine
Absolutely not at least on a flat panel TV.
I have a smart TV and three dumb flat panels! Two of them are in my trailer- the smart one and another. Basically a smart TV is one that provides connectivity and computer-likefeatures-- playing video/audio files, internet, etc. The TV part is really no different from any flat panel.
It is true that there is a shift in frequencies for the new digital broadcasts. The batwing with the HD (Nose) added is an excellent antenna; however, it was tuned to the older frequencies. You can make a simple upgrade by getting the Razor retro kit as it uses the same crank and bar system that the batwing uses.
08-15-2015, 09:33 AM
1981 31' Excella II
New Market
, Alabama
If you read the reviews that Razar is not as good at the Sensar with the Wingman upgrade or the new Sensars have that Wingman built in.
King Jack makes an antenna that fits the Wingard Base and Arms that is probably the best deal.
Perry
