06-29-2016, 11:49 PM
#421
Salem
, Oregon
Garmin RV 760 B-20
Hi, This morning I revamped my backup camera. With my sensor mounted inside of my left tail light housing, the signal was just too weak. I moved the sensor to my home made generator inlet and ran my camera wire through the conduit to the rear of my trailer. I wound up the extra wire and left it in my bumper storage compartment. I re-routed the camera wires down and to my generator outlet. Since there is no easy access to a running light wire, I added a two wire connector and I will just plug my backup camera into my Battery Tender lead. I now get a good signal.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
06-30-2016, 10:44 PM
#422
2019 23' International
Portland
, Oregon
I ended up with the Costco wired. Welded a little bracket for the wire and ran it underneath.
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
07-02-2016, 07:45 AM
#423
2016 27' Flying Cloud
Saint Robert
, Missouri
07-13-2016, 11:46 PM
#424
Salem
, Oregon
Hi, in the past few days I have painted the coupler ball area bright yellow so it can be seen better than the gray. I also was able to pull my trailer forward so I could adjust the back-up camera alignment lines. I re -adjusted the alignment lines because I lowered my camera's angle.
07-14-2016, 08:06 AM
#425
2007 30' Classic S/O
Somewhere
, South Carolina
Robert,
Great minds think alike. I put a traffic cone out as a target too and put down a length of pvc pipe as guide. Still wish the resolution was better.
07-14-2016, 01:05 PM
#426
2008 20' Safari SE
Charlotte
, North Carolina
Really great idea. Any paint suggestions?
07-14-2016, 01:24 PM
#427
2008 20' Safari SE
Charlotte
, North Carolina
Last month, a couple of pages back, I kicked out the idea of using an old, deactivated cell phone as a rear camera and another as a monitor. I ultimately decided to use both old phones as cameras. Mounted each inside the rear window, with one facing straight back (for rear-view while driving) and the other pointing as far down as I could (for backing, if needed). For the monitor, I used my current phone mounted to the dash, where I could select either or both cameras as desired.
Just back from a 5,000 round mile trip to Montana using the new "system". WOW! I cannot believe how much more fun it is to drive when you can see behind you.
Not bringing this up because I would necessarily recommend doing what I did -- you'd need to be a bit of a tinkerer, have an old phone laying around, and be willing to deal with some potential bugginess -- but it does now seem clear that we should all have some sort of rear view system.
07-14-2016, 01:48 PM
#428
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Originally Posted by teagues
...it does now seem clear that we should all have some sort of rear view system.
Based on our own experience, we completely agree. 😊
07-14-2016, 05:19 PM
#429
2012 30' International
Pleasant Hill
, The Golden State
Hey W4NT3D
I like the idea of using a GoPro and viewing with the iPad, which I use for navigation. Seem to remember that GoPro told me the image would not always be in real time. How is your experience with this set up?
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
07-14-2016, 06:16 PM
#430
2004 28' Classic
Fresno
I installed the Garmin BC30 on my 28. The reviews were so so but I am happy with the result. I bought the extension and ran the wire inside and mounted the transmitter on the front of the propane cover. It is wired to the running light and while not high definition suits my needs for backing and checking while passing other vehicles.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
07-14-2016, 10:39 PM
#431
Salem
, Oregon
Hi, this is what I used.
Rust-Oleum
Painter's Touch
2 X
Ultra Cover
Paint + Primer
Gloss / Sun Yellow
07-17-2016, 06:50 PM
#432
Saint Robert
, Missouri
Originally Posted by wildwoodrver
Hey W4NT3D
Wildwoodrver,
i was very pleased, I used it this weekend. I suction cupped my GoPro to the table instead of hanging from overhead storage. I plugged it in the inverter outlet under the dining table. I used a iPad mini to wifi to camera. I noticed some lag(less than a sec) at times and other times it would freeze up, but not that often. This setup works for me, I like it.
Oh, by the way, just remember the camera is facing backwards, don't freak out when it looks like there passing you on the right at 70+ mph, like me.
07-17-2016, 09:25 PM
#433
Salem
, Oregon
Hi, well today after some thought, I modified my camera bracket and mounted it in the middle of my trailer. I don't know why I didn't think of this in the first place. No holes, just two sided tape.
07-20-2016, 10:58 AM
#434
2015 25' FB Flying Cloud
Manassas
, Virginia
I had a Voyager system installed by dealer on our Airstream before we picked it up - top video. Then I recently was sent a new "not yet released" model from the manufacturer that I reviewed - bottom video. Both work great. I use the stock reverse camera on my 2013 Ford F150 Raptor to hitch up. Been very happy with the Voyager and have had no video connection issues at all in the year we have been using.
07-21-2016, 05:31 PM
#435
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
In the truck, we just screwed the suction cup to the top of the dash and remove the adjusting screw to remove the unit. Did the same to the base in the Mercedes. They don't fall down any more.
07-21-2016, 07:11 PM
#436
2012 27' Flying Cloud
W
, New England
I hated the suction cup holder on the Voyager screen. I replaced it with a suction cup (100x better for to windshield) with a magnet setup that has worked perfectly for me. I think it was this model:
http://www.walmart.com/ip/Scosche-MA...&wl13=&veh=sem
07-24-2016, 03:22 AM
#437
1982 31' Excella
Rolla
, Missouri
I recently purchased Garmin RV 760LMT w/Wireless Backup Camera. My next road trip kicks off in a few weeks. Lookiing fwd to posting some postive results.
Traveling Nanas'
Edith & Cheryl
1982 31' Excella / ProPride 3P
2000 F250 7.3L PSD
11-04-2016, 04:17 PM
#438
2015 28' Flying Cloud
Durango
I just installed the Pearl RearVision system and am quite impressed. This dual HD camera wireless system in a license plate frame is super wide angle, pans vertically and horizontally, has proximity alarm, and uses the iPhone as a monitor. Power and CPU are in a small module that plugs into the vehicle OBD port. Cameras are solar powered - not a single wire to connect. Installation and setup took less than 30 min. Very crisp image with instant smooth motion. Camera to CPU to iPhone communication is via WiFi and Bluetooth, and is working fine from the rear of our FC23FB to the dash of our Grand Cherokee. I've tested it while hitched up in our driveway, and will take it out for a longer road test in a few days.
Details at PearlAuto.com. Purchased via Amazon with Prime delivery. It is not inexpensive at $500, but I've tried and returned several less expensive camera systems. It is not assured to work on a travel trailer, but with a 30 day return, I gave it try and am pleased. The quality and technology of this start-up product by ex-Apple engineers is impressive.
Safe Travels,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
11-04-2016, 05:41 PM
#439
Green Cove Springs
Sounds very cool. Don't want to seem negative, but what about using the cameras after dark? We don't like to drive at night, but sometimes have to.
11-04-2016, 08:51 PM
#440
2013 28' Flying Cloud
Central
, Canada
Safe Travels,
JamuJoe
When I called this company their customer service told me that this system was designed (only) to be used as a back-up camera. They indicated that it would not function above a speed of something like 5 MPH. The person I spoke to said they did not want the system to be a distraction and that is why they put the speed control in the software.
Have you had a chance to try the system while driving? Can you confirm if it will work at higher speeds?
Thanks in advance
Doug
Trying to use my camera to create memories - not photographs!
