I'm helping someone install solar panels on the roof of her
1967 Airstream. She wants to live in it full-time, so she's like a modern system with about 500 - 600 watts of solar.
I've read that the skin on the Airstream is .032" (0.8mm) thick. Given that, any tips on attaching the panels? Use the frame (rivet lines) I'm guessing?
She's thinking about going frameless for weight savings and aesthetics. Is that common for Airstreams? Has a mounting solution been worked out? Or better off using traditional framed panels?
Or maybe she should consider flexible? Are there flexible panels with modern specs (200 - 250 watts, ~36 volts)?
Any tips on mounting, and wiring?
Thanks for any help.
