Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Generators & Solar Power
Old 06-14-2019, 01:19 PM   #1
2019 26' Flying Cloud
Greer , South Carolina
100 watt solar with deep cycle flooded batteries?
I have a 2019 26’ Flying Cloud RBT. I bought a 100 watt solar panel that I have rigged to plug into the zamp plug on my camper. The batteries are deep cycle flooded I think (Interstate). I wonder if the are OK to charge with solar and in what mode (normal, float, etc.) should I set the solar controller? Thanks for any good advice!
Jfarthing is offline   Reply With Quote
Old 06-14-2019, 01:49 PM   #2
2017 27' International
Fall City , Washington
The Zamp plug connector is likely wired opposite of your aftermarket panel as I have read. For some stupid reason, Zamp wires the plug where hot is ground and ground is hot. Check with a continuity tester. Easy to reverse leads.
Also, did your panel come with a MPPT controller? If not, you’ll need one. wire panel to controller, then controller to Zamp plug/ battery.
2017 27FB International
2013 Ram 2500 Laramie Crew Cab CTD 4x4
Lara Me is offline   Reply With Quote
Old 06-14-2019, 01:50 PM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Your batteries are fine, just make sure you check cell levels and keep them at the right place. Most portable panels that size come with a built in controller that will do it right. If not, the controller should be multi-stage that automatically changes the charge profile, you should only have to position a switch for the type of battery.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-14-2019, 03:18 PM   #4
I read that the “float mode” voltage is default set to 13.8 volts. I can adjust if needed. Is that correct for deep cycle batteries?
Old 06-14-2019, 08:53 PM   #5
2007 27' International CCD FB
San Diego , California
Almost all solar chargers are setup by default for flooded lead acid.
Charging mode for normal/float etc. is automatically managed by the charge controller depending on the state of charge of your batteries as detected by voltage level.
Nothing more to do or configure in your case other than to plug it in with the right polarity.
pteck is offline   Reply With Quote
Lithium or Deep Cycle Batteries? ScottandMoni Batteries, Univolts, Converters & Inverters 93 05-10-2019 09:33 AM
AGM to Deep Cycle Batteries Bradley G Batteries, Univolts, Converters & Inverters 18 05-04-2019 09:09 AM
Lithium Batteries or Deep Cycle? CamanoIsland Generators & Solar Power 29 06-02-2018 05:46 AM
Suggestions on Upgrading stock coach batteries to 400 Watt from stock 160 Watt odonnell71 Sprinter and B-van Forum 5 05-07-2017 07:59 AM
Question on trickle charging 2 marine deep cycle batteries bonginator Batteries, Univolts, Converters & Inverters 0 10-24-2010 12:55 PM
