Old 02-12-2011, 07:43 AM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Minus these lights
My Tradewind did not come with backup lights, scare/porch light and front and rear running lights. Mine must have been the econo model or these items were an option in 1967 and were not included on mine. So... for those that do have them or those that don't and wish they did. Should I add all of them, some of them or leave as is? Also, know that I currently have my trailer completely stripped of interior of everything including interior wall panels, wiring and have replaced entire floorboard. I'm currently insulating then comes wiring, so now would be the time if I am to add any additional lights. Recommendations on which to add and what type ( I've changed to LED stop/turn and side markers and am most likely going LED in interior). I doubt that backup lights for my model year are still available but am open to alternatives. Have also read issues of lens melt involving the scare/porch lights.
SilverHoot is offline   Reply With Quote
Old 02-12-2011, 08:25 AM   #2
The original round backup lights are still available.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-12-2011, 09:03 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
The TW should be wired for backup light lights if it's like my 67 Safari. Look for a black wire. I found the backup lights at the local auto parts store. Peterson makes this style.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-12-2011, 09:11 AM   #4
1972 21' Globetrotter
nc , North Carolina
my globe trotter had backup lights, useless. i turned them into extra stop and running lights.
rock60 is offline   Reply With Quote
Old 02-12-2011, 09:17 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Don't know when RVs dropped them, but newer model Airstreams don't have backup lights. Only brake & running & marker lights display at the rear of my '06. Other discussion - Backup lights?
5 meter Langford Nahanni
Old 02-12-2011, 09:40 AM   #6
dznf0g's Avatar
Oswego , Illinois
My 07 has BU lights.
Old 02-12-2011, 05:57 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
What good are backup lights other than to warn someone you are backing up? You can't see anything with them, especially if the backup lights on the TV work; the reflection off of the front of the trailer would block any view you might have.
Old 02-12-2011, 06:13 PM   #8
Ottawa , ON
The only real reason I can imagine to have B/U lights would be to warn people behind you of your intentions.
Old 02-12-2011, 06:50 PM   #9
SilverHoot's Avatar
1967 24' Tradewind
OK, no backup lights for me. How about the others?
Old 02-12-2011, 09:16 PM   #10
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
The front and rear running lights are kind of nice to give you a quick check on the trailer while towing at night. It tells you if the lights came unplugged or if it is swaying. I would recommend a light on each corner.
Just an opinion. Clearance lights on the top rear wont give you any added benefit other then more visibility to other cars.
Am I understanding you right? You have no running lights at all?
ddstech is offline   Reply With Quote
Old 02-12-2011, 09:24 PM   #11
SilverHoot's Avatar
1967 24' Tradewind
No Matt, I do have running lights on the sides only, none on the front or back. Lots of AS's have three in front and three in back. Yours did and my wife liked the look of them, just got a thousand other things to spend $$$ on and wonder if I really need or should make any more holes in the trailer.
Old 02-12-2011, 09:27 PM   #12
1965 17' Caravel
Birmingham , Alabama
For me, adding extra lights makes another set of holes in the shell and another potential leak path. Then there's the added maintenance to keep them working and then from deteriorating. Maybe it's a blessing not having these extra lights. That said, I do like having the "scare" light as a porch light. Also, maybe you should run a wire for the backup lights and tape it off inside the wall. Later you might decide it would be nice to have power for a back-up camera.
gwchitty is offline   Reply With Quote
Old 02-12-2011, 09:40 PM   #13
SilverHoot's Avatar
1967 24' Tradewind
Cosmos,
I like your reasoning. THANKS! Even though the scare would add the biggest hole of all....
Old 02-12-2011, 09:44 PM   #14
SilverHoot's Avatar
1967 24' Tradewind
Or are they surface mount?? Just googled and 1st I came across was surface mount.
Old 02-12-2011, 10:26 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Marker lights
I am not really sure about this but I believe operating running/marker lights are required by law. Why would AS or any other builder put them on if they weren't required.
Old 02-13-2011, 05:47 AM   #16
1965 17' Caravel
You don't have to be conventional with the scare light. I like the look of the flush mount Signalstat scare light but it is a huge hole to add. You could add a surface mount lamp but then you need a switch inside and another huge hole. I added a surface mount lamp over the old, obsolete round convenience outlet lamp socket. It's a license plate lamp and I can reinstall the old outlet again if I want to. There's a pic in my profile images. My philosophy is to try not to add any holes bigger than a rivet can plug later if I change my mind.
So here's an easy alternative. Pick up a silver-colored led solar garden lamp at Walmart for $2. Prop that up outside for a porch light. You can always add the original style lamp later, it wires to the adjacent wall lamp thru a switch.
Old 02-13-2011, 05:54 AM   #17
1965 17' Caravel
As far as lights required by law? I think this is mostly a requirement for the manufacturer and it changes every year or so. You should be fine with what came on the trailer but all those lights have to work correctly to avoid a ticket.
Old 02-13-2011, 06:00 AM   #18
DougZ's Avatar
1972 27' Overlander
Venice , Florida
I'll be the oddball on the back up lights. I like them since we often arrive after dark and it gives my wife a little better view of where I'm backin in to. It makes rocks, logs, etc. easier to see. She has a flash light, but the back up lights on our Overlander are bright and give her a much better view.
DougZ is offline   Reply With Quote
Old 02-13-2011, 08:37 AM   #19
1967 22' Safari
1960 Caravel
Images: 8
I like them too. I can see them on while backing and they do come in handy.
Really helps if you don't have a spotter at night. The wires should be there and it is a fairly easy upgrade.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 02-13-2011, 08:45 AM   #20
SilverHoot's Avatar
1967 24' Tradewind
The wires definitely aren't there on mine. Though they probably were. I'm replacing all the wires since mine was one of the few years wired with aluminum wiring.
LED Lights on 87 345 rear tail/turn Myrtle lynn Classic Motorhomes 19 02-28-2011 09:43 PM
Adding lights Summertime Batteries, Univolts, Converters & Inverters 3 02-11-2011 10:24 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
access recessed LCD lights TROB Lights - Interior & Exterior 1 01-12-2011 02:37 PM
