Old 03-31-2012, 02:35 PM   #1
stowaways's Avatar
2007 27' Safari FB SE
1969 31' Sovereign
Ft. Worth , Texas
Level or slope
Finally installing the fiberglass puzzle also know as the bathroom in our '69 sovereign 31'. This sounds like a dumb question, but is proving to be one of great significance and headache! How much slope do you need from the shower drain to the new gray tank. Ah, yes, new gray tank. There's room for at least an 1" in a bit over two feet. Causes problems though, because then we have to raise tub slightly which throws off all seven pieces of fiberglass puzzle and blah, blah... Someone say it can practically be parallel and it will still drain... Please! Lol
Sammie, Krystal, Lucas, Spencer & Jake!
stowaways is offline   Reply With Quote
Old 03-31-2012, 02:43 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
1/4" drop per foot for a drain, but in a tight spot, 1/8" is ok. Horizontal is not ok because the hair will not move along well and too much (several inches per foot) means the hair will get left behind as the water flows too fast. You are cool for a shower.
Gene
Old 03-31-2012, 02:44 PM   #3
stowaways's Avatar
1969 31' Sovereign
Ft. Worth , Texas
I could always just level the trailer 1/4" slope? Lol but seriously... Thanks gene!
Question on 2nd /AC or generator input mefly2 Electrical - Systems, Generators, Batteries & Solar 9 06-18-2012 08:04 AM
Need help, replace rivets or try to seal? timzog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 04-25-2012 11:40 AM
USB Modem using Verizon or AT&T networks zlee Computers, Internet & Satellite 10 04-04-2012 11:04 PM
Has anyone here actually cracked or broke a front wrap around window?? VonLuck All Argosy Trailers 30 04-01-2012 09:31 AM
Restore or replace leaf spring axle? silverwoman Axles 7 03-29-2012 08:33 PM
