Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 07-21-2011, 09:46 PM   #1
mineola , Texas
'79 Sovereign rear bath dripping water underneath!!
Need Help! I have what I am pretty sure is a fresh water leak that is dripping from the bottom of the drivers rear aft bumper. I crawled under the trailer and removed the sheet metal access and felt between the black water tank and the bottom and it is wet. I have checked the sink and shower and all the grey water lines and everything is dry. All fittings seem to be tight and dry. How do i get to the toilet connections? Inside the trailer is dry. When I shut off the city water the dripping stops. Pretty sure the obvious is right in front of me but cant see the forest for all of the trees>>. Thanks in advance. AL
al franklin is offline   Reply With Quote
Old 07-21-2011, 09:50 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
You have a winterizing valve open near the regulator
or
the pop off is stuck open
or
you have a broken fresh water pipe.
The fresh water tank is in the center if it's like mine.
Old 07-21-2011, 09:54 PM   #3
The 111 high pressure pop off valve is leaking.
Replacing it solves the issue.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-22-2011, 07:44 AM   #4
mineola , Texas
After looking at the service manual and where the water is dripping, the relief valve must be the problem. So how do you get to that puppy?? Through the aft access door or from underneath? Is this an AS specific valve and if so am I damaging anything continuing to have water connected to the trailer while waiting for the part to arrive?
Old 07-22-2011, 07:46 AM   #5
The dipping water problem, won't hurt anything associated with the trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-22-2011, 09:36 AM   #6
Splitrock's Avatar
Check out this thread
http://www.airforums.com/forums/f227...uet-69335.html
pop off picture
It might be stuck open or have a crumb in the seal.
It's easily taken apart and cleaned.
Old 07-27-2011, 06:33 PM   #7
mineola , Texas
I still cant find the darn pop off valve on my trailer.
Old 07-27-2011, 07:23 PM   #8
Splitrock's Avatar
Maybe you don't have one. Did you visually track you water lines all the way to the water heater? My service manual doesn't show one for my model year, but there's one installed as original equipment in my trailer.
Old 07-27-2011, 08:47 PM   #9
mineola , Texas
You could be correct. I will keep looking. I dont have the copper plumbing like in your pictures. Its the red plastic stuff.......
Old 08-03-2011, 04:07 PM   #10
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Hello Al,
Sorry about your water problems. I'll send you a message about who may be able to help you.
Lance
Lance M is offline   Reply With Quote
sovereign
Need help with Rear Bath falling out. Slowride66 Repairing/Replacing Floor &/or Frame 32 06-17-2012 05:10 PM
AC dripping water inside pappy19 Furnaces, Heaters, Fireplaces & Air Conditioning 6 04-10-2011 06:41 AM
Painting Rear bath options SilverHoot General Interior Topics 11 04-07-2011 08:31 AM
Replacing the floor in a rear bath elkie2331 Repairing/Replacing Floor &/or Frame 4 04-04-2011 07:35 PM
