Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 04-30-2006, 04:12 PM   #1
acton
63 tradewind bathtub removal
Ive got all the visible rivets drill out along the wall, screws along the bottom removed(had to drill them out) and cannot figure out whats holding that sucker in still! Any hints on whats holding it in????
Any tips are appreciated!, Thanks
Mitch
durans54 is offline   Reply With Quote
Old 04-30-2006, 05:26 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hey Mitch ~
I had the same problem, couldn't figure out why it wouldn't budge. The factory puts a layer of glue on the bottom of the tub to sit directly on the plywood and once I put my tub back in without it, it made sense. In order to get my tub out, I had to use a metal yardstick as a wedge and bang on the end with a hammer. Took some time but it eventually came out. Best of luck to you.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-30-2006, 05:53 PM   #3
acton
Brad, I appreciate it, I will get a 2x4 and rig something.
Mitch
Old 04-30-2006, 05:59 PM   #4
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Mitch ~
A 2 x 4 won't get in under neath the tub like a strong strip of metal.
Old 04-30-2006, 06:44 PM   #5
acton
Oh, okay, I get it. I will find something around here or at home depot, So I basically need to bang the wedge underneath where the tub is glued to the floor. Okay.
Thanks again.
mitch
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Olympic rivet removal and installation PeterH-350LE Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 02:22 PM
