Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Sinks, Showers & Toilets
Old 02-06-2017, 08:52 PM   #1
1965 30' Sovereign
Lake Orion , Michigan
1965 Rear Bath Plastic Sink Repair
The sink in my original rear bath has a crack in it is there any good way to repair these
mmollema is offline   Reply With Quote
Old 02-07-2017, 10:00 AM   #2
Williker's Avatar
1992 25' Excella
Orange County , New York
Epoxy or fiber reinforced Epoxy. May have to paint it to blend the color in.
Williker is offline   Reply With Quote
Old 02-07-2017, 11:58 AM   #3
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
The 65 bathroom is not plastic like later models. This is real fiberglass. You can repair with fiberglass mesh and fiberglass resin available at a good auto parts store or auto paint supply store. Then you can use Bondo, or other brand fiberglass filler. They make fiberglass reinforced version if you are worried about durability. Lots of sanding to get smooth. I repaired lots of cracks and even some holes in our 65 Caravel with this method. Afterword you can paint the whole bathroom with POR-15 Urethane Industrial Top Coat. This two part urethane is rock hard when dry. It is solid white and will make your bathroom look brand new when done. Get it here...
http://www.vintagetrailersupply.com/...-p/vts-805.htm
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 02-07-2017, 03:16 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
My sink top in my 65 was not fiberglass. I think it was some type of plastic (abs?). I had a body shop repair it with fiberglass mesh, cracked during winter! I ended up getting a stainless top made.
Cochese is offline   Reply With Quote
Old 02-07-2017, 03:17 PM   #5
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Old 02-07-2017, 06:25 PM   #6
Williker's Avatar
1992 25' Excella
It was probably acrylic.
Old 10-04-2018, 12:00 PM   #7
1965 28' Ambassador
Oviedo , Florida
Originally Posted by Cochese View Post
Noticing your picture. Which AS are you enjoying? I have a 65 Ambassador, seeking to learn from others.
Kwuser is offline   Reply With Quote
Old 10-04-2018, 04:27 PM   #8
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
It's a 65 overlander
Old 10-04-2018, 06:18 PM   #9
1965 28' Ambassador
Oviedo , Florida
Thanks.
Old 02-18-2019, 07:31 AM   #10
2016 19' Flying Cloud
Deerfield Beach , Florida
Do you have pictures of the stainless top you had made? Did you need to provide a template for them to fabricate the stainless top? Is there a place I can contact to have one made?
dominicjohn is offline   Reply With Quote
Old 02-20-2019, 05:31 PM   #11
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I made a template out of wood to have metal shop cover with stainless steel. Any sheet metal shop capable of welding stainless should be able to make it!
Old 02-21-2019, 05:11 AM   #12
Thank You
Thank you for posting photo and info, much appreciated!
Looking for a sink. Rear bath. 18" x 17.5" NigelNigel Airstream Motorhome Forums 3 06-24-2013 09:22 AM
Sink / countertop for a 1978 Argosy rear bath dryenko Sinks, Showers & Toilets 1 01-19-2012 01:46 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Lance M Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
