Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 03-07-2010, 08:54 PM   #1
fatwgn's Avatar
1965 20' Globetrotter
Janesville , Wisconsin
What Size is Black Tank
I am working on a 1964 Tradewind and would like to add a gray tank ...
Does anyone know what size (how many gallons) was the orig black tank ?? I have considerd using origanal black tank for a gray tank then adding a above floor black tank -- Has anyone added a above floor black tank??? --- PRO's and CON's for an above floor black tank ???
Also -- does anyone know if the fitting on the dump valve is still availible (Replacing valve and would like new fitting) Have pics of tank, valve - fitting on valve and also a large wasp nest under floor -- No wasp living in it -- was about 9" around
Thanks for any Help
Scott
ID:	97657   Click image for larger version
fatwgn is offline   Reply With Quote
Old 03-07-2010, 09:17 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Don't know if the fitting on your dump valve is available. The dump valve fitting on our '65 Caravel has been "out of print" for some time. Dump valve itself is available for ours, most likely for yours as well. You could check with Inland RV. They are knowledgeable, and have loads of parts. That's where I got my new dump valve.
You will need to remove the fitting from the valve to see exactly which valve you need. Someone had replaced the valve on our Caravel and installed the wrong valve. It fit OK, but didn't have the "O" ring seal needed for the fitting, so they used gobs of silicone seal. It was a bit of a job getting it apart without damaging the fitting.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
31' Sovereign's black tank size? 86Scotty 1970 - 1973 Sovereign 7 07-18-2009 07:36 AM
Need help with size of black tank replacement drowe42 Waste Systems, Tanks & Totes 2 05-25-2009 05:01 PM
Size of Black Water Tank Dureedesign 1965 - 1969 Overlander 5 05-17-2007 08:39 PM
black water tank size needed altastars Waste Systems, Tanks & Totes 5 05-30-2005 03:24 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
