Old 06-23-2017, 04:31 PM   #1
2015 25' FB Flying Cloud
Grapevine , Texas
Sewer hose storage?
Can anybody explain to me what they use the under-carraige storage tube for on the Flying Cloud 25FB? It is only 43-inches long/deep, and none of the sewer hose fittings will fit inside the tube. With its location nearby the black- and Gray-water drain, I thought it should be able to contain the hoses.
Our collapsed hose would fit, but for the over-sized fittings?
Fishing poles, broom handles, or what?
Newbie Tom
tommyglen is offline   Reply With Quote
Old 06-23-2017, 04:58 PM   #2
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We extended the "sewer" hose tubes so they could hold our flag poles on both trailers.
Old 06-23-2017, 05:03 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
We haven't found any use for it yet.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 06-23-2017, 05:07 PM   #4
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
My two sewer hoses (a 15' and 10' that I keep attached to each other) fit perfectly in my FC 23 storage tube. Of course the 45 degree angle adapter for the dump inlet doesn't fit, so that goes in my bumper compartment after getting an extra rinse.
pcskier is offline   Reply With Quote
Old 06-23-2017, 05:28 PM   #5
2007 27' Classic FB
Ridgefield , Washington
Images: 11
I use it to store my Rhinoflex sewer hose. I do need to disassemble two parts to get the hose in. (The clear elbow fits in the tube while attached) The other two parts go in a Ziplock and ride in the side storage with the leveling blocks. A bit of a hassle but don't want the stinky slinky anywhere else.
John
Woosch is offline   Reply With Quote
Old 06-23-2017, 05:56 PM   #6
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I added two longer under carriage tubes. They come in varying length, Airstream installs the shortest one. Camping world has then online. The longer 60" tube works great for the sewer hose. I did use a Dremel to grind some plastic off exterior of the clear drain extension so it fits in there too.
To attach additional tubes to the underside of the trailer get some 1/8" x 1 - 1/2" aluminum flat bar at the hardware store, cut into 2" lengths, drill 4 - 1/8" holes in each corner and pop rivet to the underside belly pan at locations where screws the new storage tube will attach. Don't screw directly into the belly pan as that metal is too thin to reliably hold screws in place.
kscherzi is offline   Reply With Quote
Old 06-23-2017, 06:18 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Some brands of sewer hoses fit, some don't.
I have cut the offending lugs of one brand to get them to fit inside the tub.
BUT...I have also lost two complete hoses when the cap comes off going down the highway.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 06-23-2017, 08:00 PM   #8
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Did the same. Also added a short 36" one on curb side by the stairs to keep mashmellow roasting supplies.
Old 06-23-2017, 10:59 PM   #9
Journeyman
2016 25' International
Amherst , Massachusetts
Newbie Tom
I keep a still-brand-new hose in there as an available extension OR just in case the queen comes by and I need to really make things fancy.
thiel is offline   Reply With Quote
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 10:41 AM
Lost my sewer hose storage tube cap Jack46 Exterior Storage Compartments & Access Doors 18 08-15-2013 07:14 AM
Sewer hose storage on Safari mgap 2000 - 2004 Safari 5 05-08-2013 10:09 AM
How can I repair or replace sewer hose storage pipe? Acker997 Waste Systems, Tanks & Totes 10 06-27-2010 01:17 PM
Sewer Hose Storage Options 66Overlander Waste Systems, Tanks & Totes 2 07-21-2007 08:30 AM
