Old 05-08-2013, 07:03 AM   #1
2004 25' Safari
Laramie , Wyoming
Sewer hose storage on Safari
Hi folks, I have been reading a bit here on the forum, and have seen some articles on sewer hose storage. Mine does not have a storage tube under the trailer and I was just wondering if this was standard on a 2004 Safari?
Since I don't have one can this be installed? or where do you keep your sewer hose if you don't have a storage tube?
mgap is offline   Reply With Quote
Old 05-08-2013, 08:18 AM   #2
aftermath's Avatar
Spokane , Washington
I have an '06 and mine came with one of the storage tubes. It didn't take long before I knew that I needed to carry a second hose to act as an extension for those times when the connection was a little too far away.
I just went to the dealer and had them install one that matched the original. Some folks make their own out of PVC pipe but I didn't want to have two different ones side by side. I believe they just screwed them to the belly pan. It didn't take long, the labor charge was minimal.
aftermath is offline   Reply With Quote
Old 05-08-2013, 08:30 AM   #3
2004 25' Safari
Laramie , Wyoming
Thanks for the reply.
So, I think I will look into getting PVC pipe and paint it the same color as the underbelly, I'll probably secure the ends with bolts through the cap and pipe. I will need to find out where and what to secure it to the underbelly.
Old 05-08-2013, 08:34 AM   #4
aftermath's Avatar
Go to your local home improvement store and look in the plumbing department. I know you can get 4 inch PVC pipe that you can cut to length, weld on a cap at one end and a threaded cap at the other. I also believe that there are pipe straps that are designed for securing this stuff down.
Do a search and you should find all sorts of information about doing this. I remember reading about and seeing pictures of these projects.
Old 05-08-2013, 09:12 AM   #5
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Using those search resources, I found a sewer storage project utilizing SQUARE PLASTIC FENCE POSTS. (one with a neat slide out tray utilizing plastic gutter) Advantages were: Able to load Rhino hose with ends attached, sewer gas trap thingy and valterra adapter in the tray and not lose anything. Tray might be used as a ramp for a long sewer run...
Easy project with minimum tools and expertise required. Heck, I did it! all materials available at the local big box hardware or maybe the farm co-op. here is one.
http://hulahutrvmods.blogspot.com/
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at https://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 05-08-2013, 10:09 AM   #6
Retired.
. , At Large
Valterra A04-0153 White 64" EZ Hose Carrier : Amazon.com : Automotive
