Old 11-08-2019, 11:33 AM   #1
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Removing sewer rain guard (or entire pipe!?)
I am trying to overlay a large sheet of aluminum over the damaged roof of my 2019 sport FB.
The sewer vent has a rain/debris guard (I assume that is what it is?). I got the actual guard plate off, but can’t quite see how to get the “leg assembly” off without cutting it. Clearly there is a seam between these two parts. Not sure if it’s glued, screwed, press-fit, ....?
Any ideas?
Would really like to avoid removing the mess of caulk (though now that I think about it, I might end up needing to do that so that I can get the new skin right against the pipe...)
ID:	355805Click image for larger version
doughpat is offline   Reply With Quote
Old 11-08-2019, 04:42 PM   #2
2007 22' International CCD
Carefully clear off the caulk at the base, and you may find fasteners that hold it down. Try a thin, flexible putty knife with rounded corners to avoid gouging aluminum. Then unscrew the fasteners and pull it off.
Old 11-08-2019, 06:13 PM   #3
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Ok. Had a feeling it might be something like that. I think that removing the caulk is going to be necessary to get the new skin to sit flat anyway.
Old 11-08-2019, 06:56 PM   #4
doughpat's Avatar
2019 22' Sport
Bend , Oregon
Rmkrum you were spot on. Scraped it and found 4 phillips metal screws. Easy!
Now the hardest part: removing the Zamp prewired housing....not seeing a good way to free it from the wiring.
Old 11-08-2019, 08:24 PM   #5
Can’t help on the Zamp housing. Don’t have one on my Airstream. Glad to help with the vent!
I just replaced one of mine that was basically flat out gone, and I have one more to do. I’m replacing with the pivoting “snorkel” type vents to help pull gasses out of the tanks.
I had a huge glob of caulking to clear off to get to the screws. Airstream must buy the stuff in 55 gallon drums and put it on with a shovel!
Old 11-09-2019, 10:35 PM   #6
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Yes they do get it in drums they dispense it with a hose. I saw them doing it at the factory.
bibbs is offline   Reply With Quote
entire 1991 airstream 34' excella the entire trailer all parts EVERYTHING woodmon8 Airstream Classifieds 1 03-13-2015 12:45 PM
Rain, Rain, Rain knunut Off Topic Forum 12 01-10-2013 07:25 PM
Rain V. Walbernize - Rain Wins monkeypants Our Community 0 08-22-2009 08:18 AM
rain guard above door Benjo Doors & Locks 4 10-03-2008 03:08 PM
Rain, rain, go away... Twinkie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2007 04:50 PM
