Old 10-29-2019, 08:54 PM   #1
Lthrncktrvlr's Avatar
2004 34' Classic S/O
Independence , Kansas
Black tank valve ext. Rod
Does anyone know of a source where I can get a extension rod that will allow the handle to be in the original bracket?Click image for larger version
S/OS #069
2004 Classic LTD 34' SO Sofa
2015 Ford F350 SRW
Lthrncktrvlr is offline   Reply With Quote
Old 10-29-2019, 09:03 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Amazon has them.
CRH is offline   Reply With Quote
Old 10-30-2019, 04:21 AM   #3
Originally Posted by CRH View Post
Amazon has them.
I have found lots of straight ones but none that have the approximately 4" offset. What terminology do you use to find them? TIA!
S/OS #069
2015 Ford F350 SRW
Old 10-30-2019, 05:48 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Try Out of Doors Mart Airstreams. I order rod and handle there but do not remember if they have the off set ones.
Old 10-30-2019, 08:06 AM   #5
I've checked their online inventory but will give them a holler and check again.
Thanks.
S/OS #069
2015 Ford F350 SRW
Old 10-30-2019, 08:50 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
I believe the "offset" rod is a custom Airstream item. Be prepared with a stiff drink when you get the pricing info. On my trailer (which uses a similar but different rod) it's up around $70.
Old 10-30-2019, 09:20 AM   #7
That's what I was afraid of. Is there any way I could get a photo of what yours looks like? I believe I'll try to fabricate my own.
Hi
S/OS #069
2015 Ford F350 SRW
Old 10-30-2019, 09:45 AM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
There are a couple photos that show similar pulls, but not the offset, at this thread>
http://www.airforums.com/forums/f444...es-162941.html
The handle comes from Airstream straight. The offset can be bent by hand using a tube bending tool. On the Excella I have now the offset is about 1.5".
I got a replacement handle/pull rod for one of my prior trailers from Out of Doors Mart.
Camco makes a variety of pulls for dump valves, cost ranging ~$10 to ~$20. I have no experience with them and do knot know if they would fit. But they look very similar.
Alan
Old 10-30-2019, 09:47 AM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
http://odmrv.com/catalog/index.php?m...roducts_id=624
Alan
Old 10-30-2019, 10:13 AM   #10
Thanks for your help. I have looked at page's upon pages of posts but not found one with a picture like what I posted that shows that angles of the rod. That's why I posted this thread.
S/OS #069
2015 Ford F350 SRW
Old 10-30-2019, 10:26 AM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
This one has more offset than mine, but is very similar.
http://www.airforums.com/forums/f444...ml#post1676732
Alan
Old 10-30-2019, 10:38 AM   #12
That's what I'm looking for! Thank you!
S/OS #069
2015 Ford F350 SRW
Old 10-30-2019, 12:57 PM   #13
And by the way, thanks for the great documentation of what this job entails! I read your thread a few times before tackling mine and did not run into any surprises.
In your pictures you always cut off the extension rod though! I was kinda sorta cussing you after I had everything operational and was looking for that ext. rod pic!
Lol, I really do appreciate all the knowledge you shared with your thread.
S/OS #069
2015 Ford F350 SRW
Old 10-30-2019, 01:08 PM   #14
3rd one is the charm?
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
On this topic...one side of the plastic finger 'pull' evaporated on my grey dump side, I'm sure the other side is not far behind. With trailer in storage, I can't look in to it. Does the rod unscrew from the gate valve to replace, or will there be more to it to replace the rod? Or...does the plastic handle easily detach from the rod? I can probably source some sort of handle from Home depot that I could put on to the end of the rod as well....
pcskier is offline   Reply With Quote
Old 10-30-2019, 01:15 PM   #15
2015 30' International
FREDERICK , Maryland
Try etrailer.com
I don't know about an offset handle, but I have purchased replacements from them.
Doc Foster is offline   Reply With Quote
Old 10-30-2019, 04:20 PM   #16
Milton , Florida
This link will show you the dump valve rode with two bends That will put it back into the hanger. It is quite pricey. I ended up making my own. This rod is on all classics through 2019, at least what I have been able to see.
highskyrvparts.com/Search-Airstream-parts-by-Year ROD-DUMP-VALVE-W-2-BENDS-601721
Ron Cherry is offline   Reply With Quote
Old 10-30-2019, 04:39 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Ron,
Thanks for sharing that information!
I learned something.
https://highskyrvparts.com/index.php..._category=true
Name:   Airstream dump-valve-rod-with-2-bends-601721.jpg
Alan
Old 10-30-2019, 04:57 PM   #18
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Ron,
Attachment 355291
Good info but donít try ordering from these folks. Search that name and silver trailer supply (same business) for reasons why not.
sheriff1 is offline   Reply With Quote
Old 10-30-2019, 06:37 PM   #19
You can order just the black "T" part that screws into the extension rod. Very easily unscrewed and replaced.
S/OS #069
2015 Ford F350 SRW
Old 10-31-2019, 08:07 AM   #20
Half a Rivet Short
Hi
Trailer is bundled up and in storage a ways down the road ... sorry !!!
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
HHOT ROD / Lightning Rod ROBERTSUNRUS Water Heaters, Filters & Pumps 4 07-11-2009 05:03 PM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 11:46 AM
