Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 06-14-2007, 12:07 AM   #1
1976 27' Overlander
Hackett , Arkansas
eliminating the black tank
Is it possible to eliminate the black water tank in a 1976 Overlander and run a line directly from the toilet to the outside (to the a septic tank or disposal site)?
sugarloafin' is offline   Reply With Quote
Old 06-14-2007, 05:27 AM   #2
Images: 59
It's possible but not a good idea.
The blackwater tank helps liquify the #2 by mixing it with the #1 and water. When you open the valve, the whole liquid mess flows out rather nicely.
If you eliminate the tank, the "solids" will stick to the piping and you will have a clogged up mess.
If your tank is leaking and you want to eliminate it, get a regular house style toilet. They have a water tank that provides enough liquid to get the whole business flowing. They also have a trap to seal off odors. Even in Arkansas you should freeze proof any above ground pipes.
Old 06-14-2007, 06:51 AM   #3
Naples , Florida
Great reply Markdoane,
My sentiments exactly! In Florida, a favorite routine for folks permanantly living in an RV (usually a 5th wheel) is to buy a lot in an RV park, strap the RV down to the concrete pad and then install semi-permanent PVC water and drain lines with a domestic type toilet.
Without the full-flush ability of the domestic's tank, it is difficult to get all of the solids down the drain pipe.
lewster
Old 06-14-2007, 10:05 AM   #4
1976 27' Overlander
Hackett , Arkansas
Thank you very much for the feedback. This helps alot.
Dennis
Old 06-14-2007, 10:08 AM   #5
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
No a good idea. You need the holding tank even when parked. Just letting it run out will let the liguid leave and most of the solids stay behind.
Michelle TAC MT-0
Sarah, Snowball
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Replacing Black Water Tank Tamara Waste Systems, Tanks & Totes 15 06-18-2002 10:45 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
Flushing Black Water Tank ViewRVs General Motorhome Topics 3 05-16-2002 02:59 PM
Black Water Tank Flush-Install JaceBeck Waste Systems, Tanks & Totes 0 04-30-2002 11:54 AM
