Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 06-22-2015, 06:36 AM   #1
Plasma800's Avatar
houston , Texas
store / use button not working
Ok, so the first time ever I used the store / use button -
Parked in my driveway to unload some gear. Batteries are charged and working fine. Meter reads 12.3 volts
I clicked STORE - red light went out as expected.
I clicked USE some 1 to 2 hours later, and nothing.
Any ideas?
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 06-22-2015, 07:57 AM   #2
Rich W's Avatar
I'm In , Kentucky
You don't have any lights on in the trailer in the 'use' position? There's no DC anything that's working? If so, when you set it to 'use' do you hear a click sound? That's the relay engaging.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 06-22-2015, 08:14 AM   #3
Plasma800's Avatar
houston , Texas
no click, no lights, no red light, just nothing
'15 27fb Signature
Old 06-22-2015, 08:45 AM   #4
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Batt disconnect
Could be one of five things a fuse what is called solenoid, the switch it's self or the converter and last a wire short. The switch is easy to replace and cheap. The solenoid is about $100.00 also easy to replace. If it's the converter it would be a good time to up grade to a three stage converter/charger for just a little more than a standard converter/charger. I would check all fuses first. Good camping Rand
grizbear is offline   Reply With Quote
Old 06-22-2015, 09:06 AM   #5
Plasma800's Avatar
houston , Texas
Yeah, I just have no idea which of these it could be.
The batteries were at 12.3 when I flipped it off. The trailer is brand new, we just brought it home.
I called airstream and they stated the batteries could just simply be too low - but the LP detector light is still on and the jack runs up and down.
They asked me to plug into power then check it out again.
My storage only has courtesy 110 - but that should at least be able to make the button click.
Any recommendation on the brand and model of the three stage charger? I'm interested in this.
'15 27fb Signature
Old 06-22-2015, 09:32 AM   #6
Rich W's Avatar
I'm In , Kentucky
15-20 amp service will be enough for everything except the air conditioner. I plug mine in at the house and there's no issue. If it's new the best thing is to take it back for warranty service.
When you plug up to the 110-20 amp service the red light should come on, regardless of the 'use' switch position. Try switching between 'use/store' and listen for the relay to click. If you still don't get a click either the relay has failed or it's not getting any power so that it can engage. On mine, there are fuses located in the same area as the relay. Use a multi-meter or test light to check those fuses, maybe one has blown. That area is very difficult for me to get to, hopefully, yours is easier. . There are several different kinds of fuses, ATC automotive type and cartridge fuses. DISCONNECT THE BATTERIES or you may short out a good fuse. (Ask me how I know.) Some of those cartridge fuses are fairly expensive, like $30-60.
If the relay doesn't come on you should still have power to the lights, microwave, Fantastic Fan, etc. I don't think it will charge the batteries unless the 'use' relay is engaged. If the converter is working it will provide the power necessary to engage the 'use' relay.
If your converter has failed, see if you can upgrade to a better one and just pay the difference. I upgraded mine to Progressive Dynamics (PD4655V) 55 Amp Converter/Charger with Built-In Charge Wizard.
-Rich
Rich & Yvonne
Old 06-22-2015, 12:15 PM   #7
Plasma800's Avatar
houston , Texas
UGH just lost my WHOLE reply... frustrating.
TLDR: Don't have correct adapter yet to step down to 120 outlet. Will obtain, try on extension cord at storage.
Access to goods under bed very limited, didn't have time to gain proper access. All appeared in good order.
Switch itself appears a little shaky (flakey).
Will look into progressive, like their brand.
'15 27fb Signature
Old 06-22-2015, 12:25 PM   #8
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My switch broke within a couple of months use, I checked battery terminals, cables at the solenoid, the fuses at the solenoid terminals, and 12v fuses. I told my service writer of what I checked, and suspected the switch itself, it just felt broken.
It would switch off all day long (audible snap) but never on.
They confirmed with a new switch, that fixed it.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 06-22-2015, 12:32 PM   #9
helotes , Texas
I had a very similar thing happen to my 2004 19 footer. It was the solenoid. Easy fix for a DIY job. Not too expensive at any RV repair place. Good luck...
aldamiani is offline   Reply With Quote
Old 06-22-2015, 01:27 PM   #10
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Seems like the switch itself is bad.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-22-2015, 01:57 PM   #11
Plasma800's Avatar
houston , Texas
I could easily just try another switch... if putting power on the unit doesn't work, I'll replace the switch, should be a simple diy thing and see if that helps.
'15 27fb Signature
Old 06-22-2015, 02:06 PM   #12
Plasma800's Avatar
houston , Texas
Anyone know how to find one of these swtiches... I know it's a common switch, but I'm just not sure what they are called.
'15 27fb Signature
Old 06-22-2015, 02:20 PM   #13
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Batt disconnect
My light was not working a month or two ago its was a loose wire at the solenoid it could also be a loose connector at the switch. The converter/charger I installed was a progressive dynamics PD4655 it works great plug in camper to a 110 volt outlet and turn the batt disconnect switch to use even if the light is already on, and it keeps the batteries well maintained. You stated your batteries read 12.3 volts that is near the low end don't let them get below 12.15 volts or they will be damaged. Full charge is in the 12.75 to 12.9 range. If your camper is new I would return to dealer for repairs. Good luck Rand
Old 06-22-2015, 02:34 PM   #14
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Battery disconnect switch
Its easy to pull 4 screws then a plug with three wires (I think 3) take it with you to your local RV repair center I was surprised my local RV shop had one in stock we tried that first then found the loose wire at the solenoid. Was glad I removed the sofa and replaced it with two la-z-boys just pulled the back off the la-z-boy and the cover over the solenoid. Good luck Rand
PS: there is also a fuse at the solenoid
Old 06-22-2015, 05:56 PM   #15
Plasma800's Avatar
houston , Texas
Yep, I have an appt with my favorite RV place in Houston, and they say that if I notify airstream first I could get reimbursed. The local dealer isn't someone I want to do business with.
I can't figure out how they arrived at 12.3 so quickly.
I was at a park in Louisiana, plugged in for days - I drove 7 hours home with the fridge on propane, and that night they were at 12.3. I ran the fans and lights while we unpacked, ~ 3 hours. The net morning we went to unload the fridge, and the meter still read 12.3
We unloaded the fridge, turned it off, hit the store switch.
So what boggles me is that in a 7 hour drive, the batteries went from fully charged to 12.3, yet over night and after 3 or 4 hours of battery use, the next morning, the level didn't drop at all.
'15 27fb Signature
Old 06-22-2015, 06:39 PM   #16
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Batt level
What are you using to check the batteries? You need a good quality multimeter one of those $30.00 jobs will not give you repeatable readings I bought a Klein about $100.00 at home depot, fluke is the other brand you can depend on they run $160.00 and up. If you are going to be an airstream camper for a good while it pays to have a good multimeter. Keeping batteries maintained is not hard but does require keeping an eye on there state of charge. It took me two sets of batteries to learn the proper battery care. I got 4.5 yrs out of the last set and they were cheap ones from auto zone I now have two 6volt golf cart batteries run in series they are great with the new 3 stage converter/charger I have about 30% more battery capacity and I can leave it plugged in and not worry about over charge. Prior to the converter/charger install I used a portable 3 stage charger works well but a hassle to do and keep an eye on weather. Good camping Rand
Old 06-22-2015, 08:39 PM   #17
Plasma800's Avatar
houston , Texas
I was going off the meter on the control panel inside the airstream
'15 27fb Signature
Old 06-23-2015, 08:51 AM   #18
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Voltage meter
Those meters they put in AS's are a gross measurement won't give you an accurate measurement like a quality multimeter. Like I said before if you will be camping long term you will use it quite often. I also have a plug in A/C voltage meter I plug in an outlet check it after plugging in at campground then turn on the AC to see if the voltage drops under a load. $15.00 at camping world before that early in my camping days had a converter burn up due to open lead at a campground power pole almost lost camper and my dog. Walked in just as it was starting to smoke. Lucky that day but still cost $400.00 to repair. Lesson learned 11.5 yrs of camping you pick up a lot of those most the hard way. Good camping Rand
Old 06-23-2015, 09:21 AM   #19
2014 25' FB International
Metuchen , New Jersey
Your 2015 trailer is under a 2yr warranty and any part not working will be replace free of charge. If the dealer you purchased from is far from you they can always send out the replacement part.
GenXair is offline   Reply With Quote
Old 06-29-2015, 08:05 AM   #20
Plasma800's Avatar
houston , Texas
Finally had a chance to run out there with an extension cord. I plugged the unit in and immediately had a red light at the STORE/USE button.
Relay clicked in both directions of the switch, and the battery meter inside read 13.4.
I unplugged the unit, put it back into store mode.
'15 27fb Signature
Where do you store your hitch when not in use? cantdrv55 Hitches, Couplers & Balls 25 09-05-2015 07:03 PM
Use or Store button(Batteries/Shorepower Devoman Batteries, Univolts, Converters & Inverters 4 09-26-2010 10:18 PM
Use/Store Button, Assistance THEPILL 2006 - 2010 International 6 04-06-2010 08:56 PM
Go to last post button not working yukionna Forum Admin, News and Member Account Info 6 09-05-2007 04:41 PM
"Store-Use" SWitch Rleirer 2000 - 2004 Safari 10 04-17-2003 02:07 PM
